ERROR compile UDF in FLUENT automatical switch from serial to parallel
Old   July 26, 2019, 12:55
Default ERROR compile UDF in FLUENT automatical switch from serial to parallel
Christian Colás Hazeu
ga63sol is on a distinguished road
i want to compile a user defined function but when i try to compile the udf, fluent automatically switches to parallel, where the libudf folder cannot be read.
Is there a way to solve this problem?
ga63sol is offline   Reply With Quote
Old   July 29, 2019, 01:02
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
options:
1. write your code for parallel
2. start fluent in series mode and compile your code, run your cases in series mode
best regards
AlexanderZ is offline   Reply With Quote
Reading a file from 32-bit Fluent 15.0 through a UDF for DPM in parallel anthony05 Fluent UDF and Scheme Programming 0 July 11, 2014 02:52
Fluent udf in parallel Zheng Fluent UDF and Scheme Programming 1 March 21, 2013 07:19
Transient pressure UDF for parallel fluent droberts Fluent UDF and Scheme Programming 5 October 11, 2010 05:13
parallelization of serial Fluent UDF for surface reaction sri31049 FLUENT 0 September 8, 2010 15:15
Parallel UDF data passing causes Fluent to hang Tom FLUENT 2 June 9, 2006 14:17
