How to compile UDF in Linux
Old   July 23, 2019, 10:14
Default How to compile UDF in Linux
wuming
wuming is on a distinguished road
Hello there,
when I try to compile UDF for fluent15.0 in the Linux. When I try to compile with GCC, I get the following error. GS.c:1:17: fatal error: udf.h: No such file or directory
#include "udf.h"
When I compile in fluent. The following message appears in the window, I think udf is not opened correctly. Could anyone help me, please
Working...
for d in lnamd64/[23]*; do \
cd $d; \
rm -rf *.{c,h,cpp,hpp}; \
for f in ../../src/*.{c,h,cpp,hpp} ../../src/makefile ../../src/user.udf; do \
if [ -f $f -a ! -f `basename $f` ]; then \
echo "# linking to" $f "in" $d; \
ln -s $f .; \
fi; \
done; \
echo ""; \
echo "# building library in" $d; \
if [ "" = "1" ]; then \
echo "# using gcc64"; \
make ARCHC=gcc64 -k>makelog 2>&1; \
else \
echo "# using gcc"; \
make ARCHC=gcc -k>makelog 2>&1; \
else \
make -k>makelog 2>&1; \
fi; \
fi;\
cat makelog; \
done
# linking to ../../src/GS0.67.c in lnamd64/3ddp
wuming is offline   Reply With Quote
Old   July 23, 2019, 22:55
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
add in the header (1 line) of your udf
#include "udf.h"
if you do have this line, that it means, that your compiler is not installer properly
check in Ansys Fluent Customization manual how to compile UDF in Linux
best regards
AlexanderZ is offline   Reply With Quote
Old   July 26, 2019, 23:27
wuming
thank you, I will read it
Old   July 26, 2019, 23:28
wuming
#include "udf.h"
best regards
udf complie linux
Helping to compile the UDF file bulu789 Fluent UDF and Scheme Programming 5 August 30, 2017 06:15
problem with UDF compile sridhar palla Fluent UDF and Scheme Programming 8 November 3, 2016 08:19
how to compile a user fortran routine in linux xyq916 CFX 1 May 3, 2016 07:17
Fluent UDF c source file problem (Linux) jayilosa Fluent UDF and Scheme Programming 1 November 21, 2011 09:25
UDF compile error Steve FLUENT 0 October 16, 2004 14:59
