Density UDF Parallel
Old   July 5, 2019, 23:30
Exclamation Density UDF Parallel
Ali Gürcan
Daryun is on a distinguished road
#include "udf.h"
int printStopper=0; /*This is a dummy counter */
DEFINE_PROPERTY(cell_density,c,t)
#if!RP_HOST /* SERIAL or NODE */
real rho;
real temp = C_T(c,t);
PROP_rho=(-0.00357*(pow(temp,2))+(1.88*temp+753.2));
#if PARALLEL
if(I_AM_NODE_ZERO_P)
#endif
if(printStopper<=100)
{printStopper++;
CX_Message("*****Cell Temp: %3.2f Kelvin, Rho= %E kg/m3 \n",temp,rho);
#endif /* !RP_HOST */
return PROP_rho;
HTML Code:
Copied C:\Users\LENOVO\Desktop/C:\Users\LENOVO\Desktop\rho.c to libudf\src
udf_names.c and user_nt.udf files in 3ddp_host are upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v193\fluent"\fluent19.3.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ")
        1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_host")udf_names.c and user_nt.udf files in 3ddp_node are upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v193\fluent"\fluent19.3.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ")
        1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_node")# Generating ud_io1.h
rho.c
..\..\src\rho.c(9) : error C2106: '=' : left operand must be l-value
Done.
Where am I making a mistake? (Ansys v19.3)
Daryun is offline   Reply With Quote
Old   July 8, 2019, 02:02
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
PROP_rho is OTHER macro, you don't need it
#include "udf.h"
real rho;
#if PARALLEL
#endif
{printStopper++;
return rho;
also you counter is strange from my point of view
best regards
AlexanderZ is offline   Reply With Quote
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Identifying cell in parallel UDF upeksa Fluent UDF and Scheme Programming 0 July 24, 2013 12:27
Density UDF for supersonic flow David Christopher Fluent UDF and Scheme Programming 0 April 18, 2013 06:48
Fluent udf in parallel Zheng Fluent UDF and Scheme Programming 1 March 21, 2013 07:19
UDF for solid density gghazal Fluent UDF and Scheme Programming 3 November 13, 2012 04:10
