Moving mesh using UDF Define grid motion and Remeshing dynamic mesh
Old   July 4, 2019, 23:49
Default Moving mesh using UDF Define grid motion and Remeshing dynamic mesh
nguyenhoa
nguyenhoa is on a distinguished road
Hi everybody
I am facing to a dynamic meshing problem that has not yet found a solution. Hope someone can help me find a solution!
Geometric model of the problem as figure attached below.
The content mainly focuses on the red border, which is moving in each calculation time step.
At time "t0", this boundary is in position 0-0. After each time step "t", this boundary moves a length "s = u * t" with u being a given displacement velocity. thus, at the time "t1 = t0 + t" it will move to position 1-1, "t2 = t0 + 2t" will reach position 2-2, ... similarly until "t13", it will reach position 13-13 and stop moving.
The law of moving is similar to using offset tools in other CAD software, so this boundary in the moving process will be shortened over time.
I have read and know the function udf DEFINE_GIRD_FUNCTION can describe this moving but I could not find the rule to write how to move. Can someone help me find a solution, thank you very much
nguyenhoa is offline   Reply With Quote
define gird motion, dynamic meshing, moving mesh, udf
UDF Define grid motion and Remeshing dynamic mesh nguyenhoa Fluent UDF and Scheme Programming 6 July 20, 2023 03:41
dynamic mesh using define grid motion udf fredrick Fluent UDF and Scheme Programming 15 December 21, 2020 18:06
Dynamic Mesh: Remeshing doesn´t work properly maccheese Fluent Multiphase 4 June 7, 2018 06:56
UDF Problem about Grid Motion !!! Zhengyu Gao Fluent UDF and Scheme Programming 0 December 6, 2013 20:45
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
