udf - get second derivative of a converged velocity field
Old   July 3, 2019, 16:09
Default udf - get second derivative of a converged velocity field
David
uconcorde is on a distinguished road
I am trying to use ADJUST macro to get second derivatives of my converged velocity field, but I got all zero values. Here is the code and procedure I am using. Can you please help me to find any mistake I have?
# include "udf.h"
DEFINE_ADJUST(adjust_gradient,domain)
Thread *t;
cell_t c;
face_t f;
domain = Get_Domain(1);
thread_loop_c(t,domain)
   begin_c_loop(c,t)
      C_UDSI(c,t,0) = C_DUDX(c,t); // calculate d2u/dx2
   end_c_loop(c,t)
Procedure:
1) Open my .cas file
2) Interpreted udf
3) Open my converged .dat file
4) User defined -> Scalars -> 1 -> Solution Zones: all fluid zones; Flux Function: none; Unsteady Function: none
5) Solving -> deselect User Scalar 0
6) Run calculation for 1 time steps
7) Check contour plot of User Defined Scalar: all zero values.
Best,
Dv
uconcorde is offline   Reply With Quote
Old   July 4, 2019, 01:01
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you dont need scalar, change to udmi
you should allocate memory for UDMI
C_UDMI(c,t,0) = C_DUDX(c,t); // calculate d2u/dx2
best regards
AlexanderZ is offline   Reply With Quote
Accuracy of the velocity field in a low speed wind tunnel? hob Main CFD Forum 1 April 24, 2016 15:35
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 05:30
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 19, 2009 00:24
UDF for Second Derivative of Velocity Satish FLUENT 1 March 8, 2004 05:15
