February 29, 2020, 08:11 |
#21 | |
mahdi rostami
Rep Power: 6 |
DEFINE_ADJUST(gradient, domain) { Thread *t; Thread **pt; cell_t c; Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE); real voidx, voidy, voidz=0.0; { Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_N ULL); Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL); Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate); } { Alloc_Storage_Vars(domain, SV_Y_RG, SV_Y_G, SV_NULL); //Y_derivatives(domain); Free_Storage_Vars(domain, SV_Y_RG, SV_NULL); } mp_thread_loop_c (t,domain,pt) if (FLUID_THREAD_P(t)) { Thread *tp = pt[P_PHASE]; begin_c_loop (c,t) { // (C_VOF_G(c,tp)[0]*C_T_G(c,t)[0]+C_VOF_G(c,tp)[1]*C_T_G(c,t)[1]+C_VOF_G(c,tp)[2]*C_T_G(c,t)[2]); C_UDMI(c,t,0) = (C_VOF_G(c,tp)[0]*C_YI_G(c,tp,0)[0] + C_VOF_G(c,tp)[1]*C_YI_G(c,tp,0)[1] + C_VOF_G(c,tp)[2]*C_YI_G(c,tp,0)[2]); } end_c_loop (c,t) } Free_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NU LL); Free_Storage_Vars(domain, SV_Y_G, SV_NULL); //Message("C_UDMI(cell,mix_air,0) = %g\n",C_UDMI(c,t,0)); } without error and successful initializing but when i running, appear this message 'the f1 process could not be started' and automatically FLUENT closed. |
February 29, 2020, 08:17 |
#22 | |
mahdi rostami
Rep Power: 6 |
DEFINE_ADJUST(gradient, domain) { Thread *t; Thread **pt; cell_t c; Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE); real voidx, voidy, voidz=0.0; { Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_N ULL); Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL); Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate); } { Alloc_Storage_Vars(domain, SV_Y_RG, SV_Y_G, SV_NULL); //Y_derivatives(domain); Free_Storage_Vars(domain, SV_Y_RG, SV_NULL); } mp_thread_loop_c (t,domain,pt) if (FLUID_THREAD_P(t)) { Thread *tp = pt[P_PHASE]; begin_c_loop (c,t) { // (C_VOF_G(c,tp)[0]*C_T_G(c,t)[0]+C_VOF_G(c,tp)[1]*C_T_G(c,t)[1]+C_VOF_G(c,tp)[2]*C_T_G(c,t)[2]); C_UDMI(c,t,0) = (C_VOF_G(c,tp)[0]*C_YI_G(c,tp,0)[0] + C_VOF_G(c,tp)[1]*C_YI_G(c,tp,0)[1] + C_VOF_G(c,tp)[2]*C_YI_G(c,tp,0)[2]); } end_c_loop (c,t) } Free_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NU LL); Free_Storage_Vars(domain, SV_Y_G, SV_NULL); //Message("C_UDMI(cell,mix_air,0) = %g\n",C_UDMI(c,t,0)); } without error and successful initializing but when i running appear this message 'the f1 process could not be started ' and automatically fluent closed |
February 29, 2020, 09:13 |
#23 | |
mahdi rostami
Rep Power: 6 |
February 29, 2020, 09:20 |
Solver
#24 |
Are you using pressure based solver or density based? If it is pressure based, then you need to tell Fluent to specifically save gradients using the following command
(rpsetvar 'species/save-gradients? #t) before using the UDF.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 29, 2020, 09:35 |
#25 | |
mahdi rostami
Rep Power: 6 |
what is the answer for question 'species/save-gradients?'? |
February 29, 2020, 09:49 |
true
#26 |
It's not a question, rather a boolean. And the Vale is already given in my post as #t.
February 29, 2020, 09:59 |
#27 |
mahdi rostami
Rep Power: 6 |
February 29, 2020, 10:44 |
#28 | |
mahdi rostami
Rep Power: 6 |
appear message: Error: eval: unbound variable Error Object: args |
February 29, 2020, 11:10 |
rpvar
#29 |
Whole of this command need to be given in one go, along with the parentheses.
February 29, 2020, 11:15 |
#30 |
mahdi rostami
Rep Power: 6 |
February 29, 2020, 11:20 |
#31 |
mahdi rostami
Rep Power: 6 |
February 29, 2020, 11:39 |
Issue
#32 |
Then possibly the issue is not with UDF. Does the case run without the UDF?
And are there still comments starting with // instead of contained in /* */? If yes, then you should either remove those comments or put those in /* */.
February 29, 2020, 11:53 |
#33 | |
mahdi rostami
Rep Power: 6 |
DEFINE_ADJUST(gradient, domain) { Thread *t; Thread **pt; cell_t c; Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE); real voidx, voidy, voidz=0.0; { Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_N ULL); Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL); Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate); } { Alloc_Storage_Vars(domain, SV_Y_RG, SV_Y_G, SV_NULL); Free_Storage_Vars(domain, SV_Y_RG, SV_NULL); } mp_thread_loop_c (t,domain,pt) if (FLUID_THREAD_P(t)) { Thread *tp = pt[P_PHASE]; begin_c_loop (c,t) { C_UDMI(c,t,0) = (C_VOF_G(c,tp)[0]*C_YI_G(c,tp,0)[0] + C_VOF_G(c,tp)[1]*C_YI_G(c,tp,0)[1] + C_VOF_G(c,tp)[2]*C_YI_G(c,tp,0)[2]); } end_c_loop (c,t) } Free_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NU LL); Free_Storage_Vars(domain, SV_Y_G, SV_NULL); } unfortunately still there is error i think error coming from line "T_derivatives" that should be reform to mass fraction command |
February 29, 2020, 12:08 |
T_derivatives
#34 |
Well, you have nothing to lose by trying T_derivatives in your code.
March 6, 2020, 05:03 |
#35 |
mahdi rostami
Rep Power: 6 |
March 6, 2020, 05:15 |
#36 |
Alexander
Rep Power: 34 |
probably it is Index that identifies the user-defined scalar,
however, index must be > -1, so I could be wrong
best regards ****************************** press LIKE if this message was helpful |
March 6, 2020, 05:20 |
#37 | |
mahdi rostami
Rep Power: 6 |
how to change this section : Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_N ULL); Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL); Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate); for accessing the mass fraction gradients? |
March 6, 2020, 05:24 |
#38 |
mahdi rostami
Rep Power: 6 |
March 6, 2020, 07:10 |
Explanation
#39 |
-1 is actually SV_NULL and is a variable attribute defined in Fluent's variable structure. Anything more than that would be a goose chase.
For mass fractions, use Y in place of VOF. Vof_Deriv_Accumulate is to be replaced with NULL. Yes, Vector_Derivatives, Vector_Reconstructionn, as well as Vector_Gradient_Reconstruction exist. This is when user wants a gradient but not spatial.
March 6, 2020, 07:57 |
#40 | |
mahdi rostami
Rep Power: 6 |
do i should write the commands : "Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_ N ULL); Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL); Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate);" for mass fraction gradients?(modify ocde by replacing VOF with Y and etc) |
macros, segmentation error, udf |
mass fraction of species | Lilly | FLUENT | 5 | March 13, 2022 17:52 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Accessing the species mass fraction for particles data in UDF | mac_09 | FLUENT | 17 | August 9, 2017 20:15 |
Define mass flow profile with regards to species mass fraction | danS | Fluent UDF and Scheme Programming | 0 | June 20, 2017 06:21 |
