UDF weird problem
Old   June 26, 2019, 07:53
Default UDF weird problem
Ma qiyu
Sunmax is on a distinguished road
I have struggled with a UDF problem and I can‘t find same question anywhere.
Here is the thing:
I started running my case it compiled the UDF successfully and ran well.BUT when I load the auto saved case and data to resume calculation things became weird,it can't run at the beginning.
the error is:
Updating solution at time level N...
done.
Updating mesh at time level N... The fl process could not be started.
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
I used to run the same case well on another PC in fluent 15.0 using serial processing,my present fluent version is 2019R1 with same configurations.
I have tested other cases without UDF and they can resume calculation naturally.
Things like the old UDF isn't compatible new version of fluent.I put my UDF down below omiting the code detials:
#include<stdio.h>
#include"udf.h"
#include"math.h"
#define  PI 3.1415926
DEFINE_GRID_MOTION(up1,domain,dt,time,dtime)
Thread *tf=DT_THREAD(dt);
face_t f;
Node *v;
int M=10000,N=8092,i,j,I0,n;
double L0 = 0.2, x[10002], y[10002], dx[10001], dy[10001], ds[10001], L[10001], xxxup, yyyup, xup[10001], yup[10001], a = 0.05, t = 0.16, wl = 0.08,
xx1[] = {},
h1[] = {};
begin_f_loop(f,tf)
	f_node_loop(f,tf,n)
		if( n==0)
			v=F_NODE(f,tf,n);
			F_UDMI(f,tf,0)=NODE_Y(v);
end_f_loop(f,tf);
if(time<=t)
begin_f_loop(f,tf)
    f_node_loop(f,tf,n)
	  v=F_NODE(f,tf,n);
      if( NODE_POS_NEED_UPDATE(v))
      NODE_POS_UPDATED(v);
	  NODE_X(v)=xup[i];
	  NODE_Y(v)=yup[i];
end_f_loop(f,tf);
Dose anyone know how to fix that?
Sunmax is offline   Reply With Quote
Old   June 26, 2019, 21:46
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
delete this and try to run
if(time<=t)
other option: run on single core
best regards
AlexanderZ is offline   Reply With Quote
Old   June 26, 2019, 22:48
Ma qiyu
the if code controls the motion so I can't delete this part,and I ran this case on single core as I mentioned
udf
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 09:51
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 16:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 11:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 07:56
