Calling volume fraction in a viscosity udf
Old   June 13, 2019, 11:47
Post Calling volume fraction in a viscosity udf
Cristian Schwatz
Cschwatz is on a distinguished road
Hello Fluent Wizards,
I'm trying to simulate a multiphase flow in which one of the phases has a non-Newtonian viscosity. Additionally, this viscosity is a function of that phase volume fraction. I had a read in the Fluent UDF manual, as well as some other posts in this forum to come up with something. In this UDF I'm using C_VOF to define volume fraction, but I'm not using the VOF model in my multiphase simulation (I'm using Euler-Euler). Can I still use this macro, despite not using the VOF model?
So far, this is what the UDF is looking like:
#include "udf.h"
#include "sg_mphase.h"
DEFINE_PROPERTY(cell_viscosity,c, t)
/*Input parameters for the Quemada rheological model*/
real mu_quem, rrbc, k_inf, k0, shear_crit, q, mu_p, exponent, stress,
stress_div, sum_s_crit, sum_s_bracket, sum_b_bracket, e;
Thread *t_rbc = THREAD_SUB_THREAD(t, 1); /* Defining the solid phase*/
rrbc = C_VOF(c, t_rbc);
mu_p = 1020.0;
e = 2.71828;
exponent = -6.0 * rrbc;
sum_s_crit = rrbc + 0.05;
k_inf = 1.0;
k0 = (5.0*pow(rrbc, 0.7)*pow(e, exponent)) + 1.9;
shear_crit = 1.65*pow(sum_s_crit, -0.3);
q = 0.5;
stress = C_STRAIN_RATE_MAG(c, t);
stress_div = stress / shear_crit;
sum_s_bracket = k_inf + ((k0 - k_inf) / (1.0 + pow(stress_div, q)));
sum_b_bracket = 1.0 - (0.5*rrbc*sum_s_bracket);
mu_quem = mu_p * pow(sum_b_bracket, -2.0);
return mu_quem;
When I build this UDF in fluent, no errors appear in the console. However, when I try to initialize my simulation the following error appears:
Node 0: Process 10896: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
What could be causing it?
https://imgur.com/a/nvGNwPw
PS: I've attached a link to an image of the equation used to write the UDF, so it makes easier to follow how I tried to write it in #C.
Cschwatz is offline   Reply With Quote
Old   June 14, 2019, 01:46
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
try this
#include "udf.h"
return 1e7;
best regards
AlexanderZ is offline   Reply With Quote
Old   June 14, 2019, 13:30
Cristian Schwatz
Hello Alexander,
Thanks for the reply! Even though I compiled the code as you have written, it still gave me the same error outcome. By the way, why did you erase the viscosity calculation and asked the code to return a constant value? I think I'm missing something here.
Thanks again!
How to call volume fraction in UDF anubhavd FLUENT 0 November 16, 2017 08:14
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 12:44
Particle Volume Fraction UDF AP3181 Fluent UDF and Scheme Programming 4 August 26, 2015 07:53
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
