June 13, 2019, 08:35 |
segmentation fault dpm force
imane
Rep Power: 8 |
Hello!
I create a program for a new expression of a thermophoretic force (code in two parts: one for the thermophoretic coefficient and the other one in the force). when I compile it, it gives an error segmentation fault, I figure it out that I should enable this force in the dpm panel for being able to hook the thermophoretic coefficient. After that, no error was generated, but I think it would be wrong because fluent will consider 2 expressions of thermophoretic force, the default one and the force I hooked by the UDF is that so? can you please guide me! I am so confused. |
June 14, 2019, 00:48 |
Alexander
Rep Power: 34 |
fluent uses UDF if it is hooked properly
best regards |
June 14, 2019, 19:05 |
imane
Rep Power: 8 |
Before hooking the thermophoretic force I should hook the thermophoretic coefficient because my force depend on it, and the only way to hook this coefficient is to enable the thermophoretic force present in physical models. By this method fluent will considere to thermophoretic forces?
I have tried to create a new material (inert particle) with a thermo coefficent as a new physical property ( for being able to hook my udf )but it shows only the density and heat capacity after the creation of material. Is there an other way to hook the thermophoretic coefficient? |
June 17, 2019, 16:51 |
imane
Rep Power: 8 |
please, any help!! Thanks in advance .
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Segmentation fault in SU2 V5.0 | ygd | SU2 | 2 | March 1, 2017 04:38 |
DPM Segmentation Fault in UDF | jhlee9622 | FLUENT | 0 | July 1, 2016 03:21 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 15:06 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
