UDF looping over nodes of a Face
Old   June 10, 2019, 07:58
Default UDF looping over nodes of a Face
nguyenhoa
nguyenhoa is on a distinguished road
Hi everyone!
I have a question about macros looping over nodes of a face.
I knew the function is F_NODE (f,t,n) where f is face, t is thread, and n is local node index number.
my question is how can i point a node, which have a local index number is knew (n=0). For example, i have node A(x0,y0). How i can assign NODE A = F_NODE(f,t,0)?
Best regards!
nguyenhoa is offline   Reply With Quote
Old   June 10, 2019, 22:12
gearboy is on a distinguished road
Originally Posted by nguyenhoa View Post
Hi everyone!
Best regards!
Mesh structure is fixed in Fluent. You can only get the node index number of a face. You can't change it.
gearboy is offline   Reply With Quote
Old   June 10, 2019, 22:14
nguyenhoa
thank you so much!
i even have a question, how i can get the node index number of a face?
Best regards!
Old   June 11, 2019, 05:55
thank you so much!
Best regards!
int n;
Node *v;
f_node_loop(f,tf,n) // n will change from 0 to NodeCount-1 of face f
v = F_NODE(f,tf,n); // v is the node corresponding to Node index n
// now you can operate something for node v
Old   June 11, 2019, 06:01
nguyenhoa
int n;
Node *v;
well, so if v=F_NODE(f,tf,n) and I also have NODE_X (v) = x0, and NODE_Y (v) = y0 so how can i find "n"?
Thanks!
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 09:26
face looping.. water hammer.. dynamic mesh alian FLUENT 2 November 21, 2015 08:36
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
I want to use pressure of 1 face in udf that compiled on other face iman_1844 Fluent UDF and Scheme Programming 3 June 10, 2010 13:55
