999999 mpt_accept error accept failed no such file or directory
Old   June 10, 2019, 05:34
Default 999999 mpt_accept error accept failed no such file or directory
lili
lilistar-8216 is on a distinguished road
I'm trying a calculation of fuel droplet evaporation using ANSYS Fluent 19.1.
I complied this UDF to change heat generation rate at the wall between solid and fluid zone. Also I compiled UDS for getting T-derivative of mass fraction.
I can compile and load these UDFs, and initialize but when calculation starts, the error : "999999 mpt_accept error accept failed no such file or directory " occurs and calculation stops.
How should I solve this problem??
/*my UDF for boundary condition */
#include "udf.h"
#include "mem.h"
#define A 74.0
#define B 0.323
#define W_d 142.2
#define T_c 617.4
DEFINE_PROFILE(heat_profile, thread, i)
Domain *d = Get_Domain(1);
Thread *t = Lookup_Thread(d,11);
cell_t c;
real mf_d, T, T_r, v_heat,mf_dt, rho;
real time = CURRENT_TIME;
begin_c_loop_all(c, t) {
if (time == 0.0) {
F_PROFILE(c, t, i) = 0.0;
else {
rho = C_R(c, t);
mf_d = C_UDSI(c, t, 0) * rho;
T = C_T(c, t);
T_r = T / T_c;
v_heat = A * exp(-B * T_r) * pow(1 - T_r, B) / (W_d * 1000);
F_PROFILE(c, t, i) = mf_d * v_heat;
end_c_loop_all(c, t)
/*UDF for UDS*/
#include "udf.h"
DEFINE_UDS_UNSTEADY(uds_1,c,t,i,apu,su)
real physical_dt, vol, mass, phi_old;
physical_dt = RP_Get_Real("physical-time-step");
vol = C_VOLUME(c, t);
mass = C_YI_M1(c,t,55);
*apu = - mass * vol/ physical_dt;
phi_old = C_STORAGE_R(c,t,SV_UDSI_M1(i));
*su = mass * vol * phi_old/physical_dt;
lilistar-8216 is offline   Reply With Quote
Old   June 10, 2019, 06:19
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Why do you include udf.h file to times? delete this
/*UDF for UDS*/
#include "udf.h"
put your case file and compiled library into the same folder.
did you allocate memory in FLuent GUI for UDS?
best regards
AlexanderZ is offline   Reply With Quote
Old   June 10, 2019, 06:58
lili
Dear AlexanderZ,
Thanks for answering. I actually make UDF for heat generation rate and UDF for UDS respectively. That's why it include "udf.h" two times.
I can't understand the meaning "did you allocate memory in Fluent GUI for UDS"...
I tried to set UDM but it didn't work.
How should I allocate memory for UDS?
regards
Old   June 10, 2019, 07:10
Alexander
delete this
/*UDF for UDS*/
#include "udf.h"
put both your functions into one file, libraries are included once in the head of file
to allocate memory for UDS in Fluent GUI go to USer-defined -> scalars -> number of UDS change to 1.
best regards
Old   June 10, 2019, 07:19
lili
I tried this and set UDF into unsteady function. I also tried to put both functions into one file but the same error happened.
regards
Old   June 10, 2019, 07:25
Alexander
change physical_dt = RP_Get_Real("physical-time-step"); to
physical_dt = CURRENT_TIMESTEP;
put all files into 1 folder.
check again, was your UDF compiled wiouth error or not?
best regards
Old   June 10, 2019, 08:15
lili
I tried this but It also didn't work.
I could compile UDF because there is no error.
regards
mpt_accept error, udf, uds
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
