June 2, 2019, 00:38 |
questions about the UDF( DEFINE_DPM_BC )
Jim
Rep Power: 7 |
The following program is an example from the help document.When I wanted to use it, some problems bothered me.
1.f_normal contains the unit vector which is normal to the face,but in or out?(maybe it doesn't matter,I just want to know it) 2.if(p->type==DPM_TYPE_INERT) I know: #define DPM_TYPE_INERT 1(from dpm_types.h) P-> structural member (the number"1" passed by FLUENT indicates the particle type, only in my opinion) So,Is the particle type only for INERT particles to execute the program? To "p->type" ,is it assigned to 1? 3.if ((NNULLP(t)) && (THREAD_TYPE(t) == THREAD_F_WALL)) F_CENTROID(x,f,t); how to understand it? Maybe my problem will be naive, but for me as a beginner, it is really important.I hope to get help, but whatever the result, I appreciate your browsing and thinking. Thanks again! /* reflect boundary condition for inert particles */ #include "udf.h" DEFINE_DPM_BC(bc_reflect,p,t,f,f_normal,dim) { real alpha; /* angle of particle path with face normal */ real vn=0.; real nor_coeff = 1.; real tan_coeff = 0.3; real normal[3]; int i, idim = dim; real NV_VEC(x); #if RP_2D /* dim is always 2 in 2D compilation. Need special treatment for 2d axisymmetric and swirl flows */ if (rp_axi_swirl) { real R = sqrt(P_POS(p)[1]*P_POS(p)[1] + P_POS(p)[2]*P_POS(p)[2]); if (R > 1.e-20) { idim = 3; normal[0] = f_normal[0]; normal[1] = (f_normal[1]*P_POS(p)[1])/R; normal[2] = (f_normal[1]*P_POS(p)[2])/R; } else { for (i=0; i<idim; i++) normal[i] = f_normal[i]; } } else #endif for (i=0; i<idim; i++) normal[i] = f_normal[i]; if(p->type==DPM_TYPE_INERT) { alpha = M_PI/2. - acos(MAX(-1.,MIN(1.,NV_DOT(normal,P_VEL(p))/ MAX(NV_MAG(P_VEL(p)),DPM_SMALL)))); if ((NNULLP(t)) && (THREAD_TYPE(t) == THREAD_F_WALL)) F_CENTROID(x,f,t); /* calculate the normal component, rescale its magnitude by the coefficient of restitution and subtract the change */ /* Compute normal velocity. */ for(i=0; i<idim; i++) vn += P_VEL(p)[i]*normal[i]; /* Subtract off normal velocity. */ for(i=0; i<idim; i++) P_VEL(p)[i] -= vn*normal[i]; /* Apply tangential coefficient of restitution. */ for(i=0; i<idim; i++) P_VEL(p)[i] *= tan_coeff; /* Add reflected normal velocity. */ for(i=0; i<idim; i++) P_VEL(p)[i] -= nor_coeff*vn*normal[i]; /* Store new velocity in P_VEL0 of particle */ for(i=0; i<idim; i++) P_VEL0(p)[i] = P_VEL(p)[i]; return PATH_ACTIVE; } return PATH_ABORT; } |
June 8, 2019, 22:00 |
Jim
Rep Power: 7 |
Is there anyone who can help answer these questions
define_dpm_bc, fluent, udf |
udf for valve closing a pipe using dynamic mesh | chem engineer | Fluent UDF and Scheme Programming | 2 | May 13, 2017 09:39 |
some questions about the udf for specificed heat in the FLUENT 14.5 V | uuusheng | Fluent UDF and Scheme Programming | 0 | July 8, 2014 13:33 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
some questions about DPM and UDF | zhaoxinyu | Fluent UDF and Scheme Programming | 0 | April 29, 2010 09:01 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
