May 30, 2019, 17:28 |
Relative rotary motion of mesh
Łukasz
Rep Power: 7 |
Hello!
I described the goal of my project in the simple drawing below: https://ibb.co/tPcfPn3 The black circle is rotating (around its geometric center - c1) and in the same time the red circle is rotating (around c2). The problem is that the position of c2 is changing in time and the red circle is rotating back and forth - in a sinusoidal function. The question is how can I do this in Fluent? I tried to write a macro and use it in dynamic mesh and it works for the black circle so its rotating. How can I define relative motion of the red circle? I checked the option "relative motion" to dark circle in dynamic mesh but then the red circle moves in a totally wierd manner when I use the most simple macro for the black and red circle: #include "udf.h" DEFINE_CG_MOTION(turbine_om, dt, vel, omega, time, dtime) { omega[0] = 0; omega[1] = 0; omega[2] = 2; } Thanks for the attention |
June 14, 2019, 19:05 |
Łukasz
Rep Power: 7 |
I renew my question
does anybody have any suggestion? thak you |
dynamic mesh, relative motion, rotary mesh |
dynamicFvMesh - tabulated motion of a solid body + mesh morphing | HendrikW | OpenFOAM Pre-Processing | 3 | December 3, 2019 03:05 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
Dynamic moving mesh | Pei-Ying Hsieh (Hsieh) | OpenFOAM Running, Solving & CFD | 64 | June 7, 2012 11:04 |
Prescribed mesh motion does not correspond to actual motion | rbarrett | CFX | 8 | June 30, 2011 14:22 |
