Design points using UDF and time variable outputs
Old   May 16, 2019, 08:34
Question Design points using UDF and time variable outputs
Henrique Carneiro
henrique_car is on a distinguished road
Hello guys,
I am running a transient simulation on a eel whose movement and dynamic mesh is done via UDF. My run time is one period of the wave, after which it just starts over.
As I have many parameters I would like to test out, I thought about using the design points feature to vary the parameters and let it run for days without having to manually do each simulation with a specific combination of parameters.
I have not been able to do this and I have some questions regarding the design points feature that I hope you can shed some light in.
  1. Is it possible to use design points feature with an UDF?
  1. How does the output of design points work when using transient simulation and your desired output varies with time? As far as I know it gives a constant value for each DP.
  1. If this design feature can't be used/is not the best strategy to my problem, what do you recommend?
Thank you in advance and have a great day!
henrique_car is offline   Reply With Quote
Old   May 17, 2019, 01:09
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
easiest way is to use workbech and Parameters.
In UDF you may use RP_Get_Input_Parameter("variable name") macro to access parameter values
best regards
AlexanderZ is offline   Reply With Quote
Old   May 17, 2019, 08:28
ssixr's Avatar
sudhir
ssixr is on a distinguished road
you could simply read a file and store the values in an array.
Originally Posted by henrique_car View Post
Hello guys,
ssixr is offline   Reply With Quote
Old   May 18, 2019, 09:05
Henrique Carneiro
henriquecar is on a distinguished road
What do you mean? How would I do it? Could you please elaborate?
henriquecar is offline   Reply With Quote
Old   May 21, 2019, 11:59
ssixr's Avatar
sudhir
please have a look at this link https://www.sharcnet.ca/Software/Fluent6/html/udf/node260.htm
design points, transient, udf
A variable expressing time steps in UDF? lcw FLUENT 6 March 28, 2020 04:07
User defined time step - Possible to put variable time stepping in it? maccheese Fluent UDF and Scheme Programming 19 June 4, 2018 10:49
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:51
