UDF print results into .dat file more than once per time step? how to fix it?
Old   April 26, 2019, 11:38
Default UDF print results into .dat file more than once per time step? how to fix it?
xuwenhua
xuwenhua625 is on a distinguished road
fluent 19.2 , UDF in parallel
Using Compute_Force_And_Moment micro to calculate the force of a flapping foil, then printing the results into a .dat file. I found that the UDF output the same results into the .dat file 1~3 times per time step, so how can I fix the problem to print the same results in the .dat file only once in every timestep?
Thanks!
xuwenhua625 is offline   Reply With Quote
Old   April 26, 2019, 22:18
Default Another solution
xuwenhua
I find MATLAB ‘unique’ function can solve the problem~~
Old   April 27, 2019, 05:40
pianaCFD is on a distinguished road
I don't understand the problem. Do you mean that you have more iteration per time step and you want to print the results just for the last iteration of each time step? In this case you can use DEFINE_EXECUTE_AT_END macro and print from there.
If the problem is that you are working in parallel and fluent is printing the results for each node then you can try to add something like this:
FILE *try;
#ifPARALLEL
if(I_AM_NODE_ZERO_P)
#endif
try=fopen("youfile.dat","w+");
fprintf(try, ....... );
fclose(try);
pianaCFD is offline   Reply With Quote
Old   April 27, 2019, 22:32
xuwenhua
FILE *try;
#ifPARALLEL
#endif
fclose(try);
thanks! I'll have a try.
Old   April 29, 2019, 02:31
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you should write to file from HOST
more details you may find in Ansys Fluent Customization manual
it contains pretty clear example chapter Writing Files in Parallel
best regards
AlexanderZ is offline   Reply With Quote
Old   May 15, 2019, 06:33
parallel calculation, udf code
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
