UDF MACRO Usage
Old   April 24, 2019, 00:53
Post UDF MACRO Usage
kailash
kailash007 is on a distinguished road
Hi People,
I am facing an issue with DEFINE_EXECUTE_FROM_GUI. I was practicing the example from ANSYS fluent manual for resetting memory using DEFINE_EXECUTE_FROM_GUI macro. Now after successful compilation and when I run the code, the UDF is not running. I don't know how to make ANSYS run my code as there is no option to Hook it up.
kailash007 is offline   Reply With Quote
Old   April 24, 2019, 02:10
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
how do you run your code?
best regards
AlexanderZ is offline   Reply With Quote
Old   April 24, 2019, 16:38
kailash
best regards
Pardon the usage of my words. I meant running the solution in ANSYS Fluent by clicking on "Calculation", not the code.
Old   April 24, 2019, 22:37
Alexander
read what DEFINE_EXECUTE_FROM_GUI does
best regards
Old   April 25, 2019, 02:12
Svetlana Tkachenko
Svetlana is on a distinguished road
From documentation DEFINE_EXECUTE_FROM_GUI attaches to custom gui elements, which are created in scheme. I couldn't find examples of the latter, however.
Svetlana is offline   Reply With Quote
Old   April 25, 2019, 02:31
kailash
Exactly the problem. The manual says that ANSYS Fluent solver will automatically run the UDF when a call is made from a user-defined Scheme program to execute. In order to do that we have to create a User Interface I guess. Am working on it still.
Here is the link if you are interested:
https://www.sharcnet.ca/Software/Ans...-B1664497.html
udf and programming
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
UDF macro not compliled KITetima Fluent UDF and Scheme Programming 12 October 23, 2013 10:13
UDF Data Access Macro Woo Meng Wai FLUENT 0 November 6, 2007 21:23
I want to learn UDF usage in Fluent sangamnath FLUENT 5 December 17, 2005 13:16
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 11:55
