April 23, 2019, 07:31 |
UDF for Azimuth rotation of wing
Bilal
Rep Power: 7 |
Hi experts!
I am a CFD student. I am simulating a rectangular wing in azimuth rotation in Ansys Fluent. I have written a UDF for the verification and validation purpose in terms of non-dimensionalized terms. But it did not work fine. The wing is not rotating through the angle as specified in the UDF. I have used the equations in UDF from this paper. "Dynamics of revolving wings for various aspect ratios Garmann 2014" I am using this paper as my base paper. Secondly, If you could find any better paper for validating this type of motion, It would be appreciated a lot. it would be really kind of you if you could help me with this matter. Looking forward to your replies. Thanks in advance here is the UDF. /* The udf is written for Tubercled/smooth wing modeled . R/c= 4.0. Chord length of 10 mm i.e, 0.01m and Re 1000 at root of wing i.e velocity = 1.4604 m/s */ #include "udf.h" #define tau_1 0 /*non-dimensionalized start time*/ #define tau_2 1.396263402 /*non-dimensionalized End time*/ #define pi 3.1416 /*radians*/ #define a 5.2 /*smoothing factor*/ #define psi_max 2.0 /*non-dimensionalized max rotational velocity*/ #define U 1.4604 /* max linear velocity at root of wing*/ #define c 0.01 /*Chord in meters*/ #define psi_not 2.792526803 /*total rotational angle rad*/ static real psi_dot = 0.0; DEFINE_CG_MOTION(TEST, dt, vel, omega, time, dtime) { Thread *t; face_t f; real psi; real psi_dot; NV_S(vel, =,0.0); NV_S(omega, =,0.0); if (Data_Valid_P()) return; real tau = time*U/c; real value = (cosh(a*(tau - tau_1)))/(cosh(a*(tau - tau_2))); psi = (psi_max/(2*a))*log(value)+0.5*psi_not; psi_dot = (psi_max/(2*a))*(-a/cosh(a*(tau-tau_1)))*(cosh(a*(tau- tau_1))*tanh(a*(tau-tau_2))-sinh(a*(tau-tau_1))); Message("time:%f tau: %f psi:%f psi_dot:%f\n",time,tau,psi,psi_dot); omega[0] = 0.0; omega[1] = psi_dot; omega[2] = 0.0; } |
UDF for Rotation | Johnmuddy | Fluent UDF and Scheme Programming | 5 | October 25, 2016 09:44 |
flapping wing udf | moh_zain | Fluent UDF and Scheme Programming | 13 | June 7, 2016 19:23 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 08:26 |
UDF : 6DOF valve in rotation | Johnmuddy | Fluent UDF and Scheme Programming | 0 | September 18, 2014 14:53 |
flapping wing UDF code | yahya_azizi | Fluent UDF and Scheme Programming | 1 | July 24, 2012 07:24 |
