Ansys Fluent UDF, Wall Average Temperature Depend On Inlet Velocity
Old   April 13, 2019, 11:35
Default Ansys Fluent UDF, Wall Average Temperature Depend On Inlet Velocity
ozge akbulbul
ozgeozge is on a distinguished road
Hello All,
I am trying to write "UDF fluent code" that wall average temperature condition depend on inlet velocity. I have the face which ID is 9 and its average temperature depend on inlet velocity. When face average temperature increases, inlet velocity increases each time step (transient).
-I use fluent on serial
-I use it on transient, energy on, viscous- k-eps or laminar
-I have increased Number of user defined memory location
-I have interperated my code as (kod.c) (which is has no error on command)
-I have done that add function hooks on Execute at end as (execute_at_end)
-I have added inlet velocity magnitude as (unsteady_velocity)
When I run calculation, after one time step (for instance 10 or 20 iteration) I got error which is; which mean is I can't go through second time step.
Error: received a fatal signal (Segmentation fault). Error Object: #f
The code is;
#include "udf.h"
real T_mean;
DEFINE_EXECUTE_AT_END(execute_at_end)
Domain *domain;
Thread *thread;
face_t face;
real area[ND_ND];
real total_area = 0.0;
real total_area_ave_temp = 0.0;
int ID = 9;
domain = Get_Domain(1);
thread = Lookup_Thread(domain, ID);
begin_f_loop(face, thread)
F_AREA(area, face, thread);
total_area += NV_MAG(area);
total_area_ave_temp += NV_MAG(area)*F_T(face, thread);
end_f_loop(face, thread)
T_mean = total_area_ave_temp/total_area;
printf("Area averaged T on boundary %d = %f K\n", ID, T_mean);
DEFINE_PROFILE(unsteady_velocity, thread, position)
face_t f;
real t = CURRENT_TIME;
begin_f_loop(f, thread)
F_PROFILE(f, thread, position) = (T_mean-273) ;
end_f_loop(f, thread)
I would be grateful if I solve this problem with your helps, thank you very much
Best regards.
ozgeozge is offline   Reply With Quote
Old   April 15, 2019, 02:31
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you've missed brackets here:
how it is possible to have this error and no error after compilation?
change printf to Message
you have Error: received a fatal signal (Segmentation fault). Error Object: #f error, because your T_mean was not calculated, so you are trying to put -273 as a boundary condition, or any other trash
by the way, check your units for temperature, by default fluent uses Kelvin
best regards
AlexanderZ is offline   Reply With Quote
ansys, fluent - udf, inlet velocity profile, temperature dependent
UDF - Inlet Velocity Profile (Ansys Fluent) vinayak4399 Fluent UDF and Scheme Programming 3 August 25, 2020 15:15
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
UDF velocity inlet. Different values (compile - Fluent) asking FLUENT 0 July 13, 2018 18:02
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 07:45
Ansys Fluent 17 UDF Velocity Profile Update. Phil-M Fluent UDF and Scheme Programming 4 October 17, 2016 10:05
