Viscosity UDF works when interpreted, Doesn't when compiled?
Old   April 11, 2019, 07:33
Default Viscosity UDF works when interpreted, Doesn't when compiled?
Sebi
bloodflow is on a distinguished road
Hi Again,
I am learning how to compile UDF's instead of just intrerpreting them. I have successfully compiled a UDF and am using it to define a Transient velocity inlet, and a Viscosity model. The compiled UDF works correctly for the velocity inlet, but the viscosity UDF returns a constant viscosity of mu=0.00476. The same UDF works properly when compiled, is there a difference in how they should be written? The Full UDF is below.
/* Carreau-Yasuda Viscosity Model */
#include "udf.h"
double muinf=0.00476;
double mu0=0.0519;
double lambda=0.438;
double p=0.409;
double n=0.191;
DEFINE_PROPERTY(cell_viscosity,c,t)
real diff;
real shear;
real prod;
real power;
real cyvisco;
diff=(mu0+muinf);
prod=((lambda)*(C_STRAIN_RATE_MAG(c,t)));
shear=(1+(pow(prod,p)));
power=((n-1)/(p));
cyvisco=((muinf)+(diff)*(pow(shear,power)));
return cyvisco;
/* 2D Parabolic Transient Velocity Profile For Laminar Flow */
#include "udf.h"
float a0 = 0.1564;
float a1 = -0.03045;
float b1 = 0.007764;
float a2 = 0.0242;
float b2 = 0.03948;
float a3 = -0.01151;
float b3 = -0.008163;
float a4 = 0.009875;
float b4 = 0.003343;
float a5 = -0.01003;
float b5 = 0.002862;
float a6 = 0.006133;
float b6 = -0.0007519;
float a7 = 0.001413;
float b7 = 0.001232;
float a8 = -0.003654;
float b8 = -0.000137;
float w = 7.858;
DEFINE_PROFILE(LaminarCoronaryVelocity, thread, position)
real x[ND_ND];
real y;
real z;
real t = CURRENT_TIME;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
z = x[2];
F_PROFILE(f, thread, position) = (2*(a0 + a1*cos(t*w) + b1*sin(t*w) +
a2*cos(2*t*w) + b2*sin(2*t*w) + a3*cos(3*t*w) + b3*sin(3*t*w) +
a4*cos(4*t*w) + b4*sin(4*t*w) + a5*cos(5*t*w) + b5*sin(5*t*w) +
a6*cos(6*t*w) + b6*sin(6*t*w) + a7*cos(7*t*w) + b7*sin(7*t*w) +
a8*cos(8*t*w) + b8*sin(8*t*w))*(1-(y*y+z*z)/(0.00000196)));
end_f_loop(f, thread)
bloodflow is offline   Reply With Quote
Old   April 11, 2019, 09:05
pakk will become famous soon enough
You use pow, which is not a standard c function, but is included in the math library.
To include this in a compiled function, use:
#include <math.h>
Please let me know if it works, because I'm not 100% sure if this is the reason.
pakk is offline   Reply With Quote
Old   April 11, 2019, 09:17
Sebi
#include <math.h>
I have added that and it seems to make no difference.
If I make the function much simpler and just have visco=0.05*shear, the viscosity does vary, but when I include the other things it seems to mess up.
I am compiling this and running on linux if that makes any difference.
Old   April 11, 2019, 10:01
OK, that was a tough one...
Your problem is that you were using global variables. Don't use them, except when necessary. Here, they are not necessary at all.
Your global variable p is used in one of the templates that Fluent uses. Don't ask me which. But I could see that the effect was that in your function cell_viscosity, the value of p was zero. (In unix, in Windows the value was 0.409.)
So, don't define your variables globally if you only use them locally:
#include "udf.h"
double mu0=0.0519;
double p=0.409;
double n=0.191;
real diff;
real shear;
real prod;
real power;
real cyvisco;
diff=(mu0+muinf);
power=((n-1)/(p));
return cyvisco;
float a0 = 0.1564;
float a2 = 0.0242;
float b2 = 0.03948;
float w = 7.858;
real x[ND_ND];
real y;
real z;
face_t f;
y = x[1];
z = x[2];
I tried it in one of my cases, and it gave a viscosity that depended on the strain rate.
(By the way: you should only include udf.h once.)
Old   April 11, 2019, 10:06
Sebi
YES
You sir are a God amongst men!
Thank you so much for going to the trouble of finding that out.
Now back to the original problem I was trying to solve in the first place about DPM position macros........
compile, udf
Viscosity UDF Gives different Results to fluent Model? bloodflow Fluent UDF and Scheme Programming 1 March 28, 2019 21:11
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
I want to use pressure of 1 face in udf that compiled on other face iman_1844 Fluent UDF and Scheme Programming 3 June 10, 2010 13:55
error of Interpreted udf Zhang Junmei FLUENT 6 December 12, 2001 09:03
