How to solve a Poisson's equation in the beginning of each time step |
April 5, 2019, 09:18 |
Mari vonkarman
Rep Power: 7 |
Hi all.
I need to solve a Poisson's equation with determined coefficients before the solution iterations in the beginning of each time step and then some parameter outputs is to be assigned as the input for main equations (U,V,...). Is that possible in Ansys Fluent? Thanks for any attentions. M. Vonkarman |
April 8, 2019, 01:06 |
Alexander
Rep Power: 34 |
Ansys Fluent Customization manual
look for DEFINE_ADJUST macro best regards |
April 14, 2019, 03:51 |
Mari vonkarman
Rep Power: 7 |
Sure,I will study and assign your recommendation.
Thank you very much. |
July 8, 2019, 02:44 |
Hanye Azimi
Rep Power: 9 |
Hi everybody
Do you know how I should fix this error about a define_adjust UDF 'motion_spec' : is not a member of 'tv_cell_struct' thanks in advance |
input output, poisson equation, time step, unsteady |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
time step directories naming issue | Andrea_85 | OpenFOAM | 3 | April 3, 2014 08:38 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
