Problem with UDF in 2D
Old   April 2, 2019, 07:52
Default Problem with UDF in 2D
ana86 is on a distinguished road
Dear Foamers,
I want to simulate a deforming wall in 2D. The deforming depends on the temperature gradient, and I used the macro
C_T_G(c,t)[0] for the gradient in x-direction. But when I want to use this in the deforming equation, the simulation stops and fluent window closes.
I tried a simulation in 3D and it works.
Can anybody help me?
Thank you!
ana86 is offline   Reply With Quote
Old   April 2, 2019, 12:05
Sanket Dange
sanketdange2007 is on a distinguished road
Could you please post your UDF for 2D?
sanketdange2007 is offline   Reply With Quote
Old   April 3, 2019, 03:01
Sorry for forgetting to post the udf.
#include „udf.h“
DEFINE_GRID_MOTION(deformingmesh,domain,dt,time,dt ime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real NV_VEC(dx);
real T, gradTx;
int n;
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
begin_f_loop(f,tf)
T = F_T(f,tf);
gradTx = C_T_G(F_C0(f,tf),tf->t0)[0];
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
dx = 0.0001 * gradTx;
NV_S(dx, *=, dtime);
NV_V(NODE_COORD(v), +=, dx);
end_f_loop(f,tf);
Old   April 3, 2019, 07:04
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
,dt ime) in your code has space?
best regards
AlexanderZ is offline   Reply With Quote
Old   April 4, 2019, 02:07
Originally Posted by AlexanderZ View Post
best regards
Thank you, but that is just a mistake I made, when I copied the udf to this forum.
Old   April 4, 2019, 03:34
Alexander
ansys fluent customization manual
there is a chapter: DEFINE_GRID_MOTION
with example, which maybe you use as a basis of this UDF
what is the difference between that code and yours?
gradTx is a scalar
dx is a vector
this could be the problem
you've told
that was other UDF isnt it?
best regards
Old   April 4, 2019, 04:03
gradTx is a scalar
dx is a vector
you've told
best regards
Thank you, that's wrong, of course. But unfortunately this ist not the problem. I also used dx[0], and it didn't work.
In 3D i use the same udf with
gradTy = C_T_G(F_C0(f,tf),tf->t0)[1]
gradTz = C_T_G(F_C0(f,tf),tf->t0)[2]
Old   April 4, 2019, 23:26
Alexander
this is a problem, fix it
best regards
Old   April 5, 2019, 02:08
best regards
What do you mean? dx and dx[0]? I fixed it and it does not work.
Old   April 5, 2019, 03:04
Alexander
how did you fix it?
change x to x[0] ???
its not a solution
best regards
Old   April 5, 2019, 06:27
Ok, maybe I made a mistake...
But now I tried in 3D again the following code and it doesn't work anymore...
#include "udf.h"
DEFINE_GRID_MOTION(grid_motion,domain,dt,time,dtim e)
face_t f;
Node *v;
int n;
real NV_VEC(dx);
real NV_VEC(DX);
real NV_VEC(gradT);
NV_D(DX, =, 1.e-9,1.e-9,1.e-9);
NV_D(gradT, =, 0.0, 0.0, 0.0);
begin_f_loop(f,tf)
gradT[0] = C_T_G(F_C0(f,tf),tf->t0)[0];
gradT[1] = C_T_G(F_C0(f,tf),tf->t0)[1];
gradT[2] = C_T_G(F_C0(f,tf),tf->t0)[2];
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
if(NODE_POS_NEED_UPDATE(v))
NODE_POS_UPDATED(v);
NV_V(DX, *=, gradT);
NV_V(dx, +=, DX);
NV_S(dx,*=,dtime);
end_f_loop(f,tf);
if I neglect the line NV_V(DX, *=, gradT); it works.
Old   April 5, 2019, 06:59
Alexander
try
NV_D(gradT, =, C_T_G(F_C0(f,tf),tf->t0)[0], C_T_G(F_C0(f,tf),tf->t0)[1], C_T_G(F_C0(f,tf),tf->t0)[2]);
instead of
also Im not sure about tf->t0 part, try THREAD_T0(tf) if previous change is not a solution
best regards
Old   April 5, 2019, 07:45
Thank you for your help. I tried both solutions, but unfortunately it still does not work :-(
Old   April 8, 2019, 01:55
Alexander
check what value C_T_G returns
best regards
Old   April 8, 2019, 10:36
I checked, or rather I tried, but fluent also breaks up the simulation. Maybe there is something wrong with my setup...
Old   April 10, 2019, 09:26
Hey Alexander,
I found the error. I made a mistake in the setup. Sorry for that... And thank you for your help !
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 09:51
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 16:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 11:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 07:56
