Warning: UDF FLUENT
Old   March 26, 2019, 13:04
Default Warning: UDF FLUENT
hraf5
EL OMARI Achraf is on a distinguished road
Hi everyone,
I'm getting the following warning when I compiled a UDF function in Fluent. I obtained the following warning:
warning C4700: uninitialized local variable 'x' used
is this program right, or something is missing??
#include "udf.h"
#define PI 3.14
#define A 20.0
#define freq 10.0
DEFINE_PROFILE(unsteady_inlet_x_velocity, thread, position)
real y[ND_ND] ;
real x;
face_t f;
real t = CURRENT_TIME;
begin_f_loop(f, thread)
F_PROFILE(f,thread, position) = sin(15.*PI/180)*A*sin(400.*PI*(x-0.001))*sin(400.*PI*(x-0.001))*sin(freq*2.*PI*t);
end_f_loop(f, thread)
DEFINE_PROFILE(unsteady_inlet_y_velocity, thread, position)
real y[ND_ND];
real x;
face_t f;
F_PROFILE(f,thread, position) = cos(15.*PI/180)*A*sin(400.*PI*(x-0.001))*sin(400.*PI(x-0.001))*sin(freq*2.*PI*t);
EL OMARI Achraf is offline   Reply With Quote
Old   March 26, 2019, 13:28
Lucky
just follow the error message
Originally Posted by EL OMARI Achraf View Post
real x;
you declared x here
You called x here and also later but never assigned any values to x.
Check out the example from the Fluent manual. You are missing lines that should look like so:
F_CENTROID(y, f, thread);
x = y[0];
F_Centroid is a macro that loops over the face thread f and stores the centroids into variable y. Hence why you declare real y[ND_ND]; instead of just real y;
x=y[0] takes the 1st value of the centroid coordinate (the x position in this case). If you want the y coordinate then do y[1], and do y[2] if you want the z coordinate.
Old   March 26, 2019, 16:05
Default question
serrar is on a distinguished road
Thanks a lot for your advice, I did everything you asked me to do but I still get the error mentioned above
vprofile1.c(31): error C2064: term does not evaluate to a function taking 337 arguments
To clarify things, my basic equation is noted as 1:
1) A*sin(400.*PI*(x-0.001))*sin(400.*PI*(x-0.01))*sin(freq*2.*PI*t)
and concerning the X and Y axes present the projection of this equation according to these axes.
I hoped things were very clear
how can I solve this problem?
Best regards
serrar is offline   Reply With Quote
Old   March 26, 2019, 17:38
Old   March 26, 2019, 22:32
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
put here final version of your code
best regards
AlexanderZ is offline   Reply With Quote
Old   March 27, 2019, 04:14
Hello everyone,
I hope someone can compile this code and modify or correct it if there are any errors, I would be very grateful.
Best regards
#include "udf.h"
#define PI 3.14
#define A 20.0
#define freq 10.0
real y[ND_ND] ;
real x;
face_t f;
real y[ND_ND];
real x;
face_t f;
F_CENTROID(y,f,thread);
x = y[0];
Old   March 27, 2019, 05:13
Alexander
#include "udf.h"
#include "math.h"
#define PI 3.14
#define A 20.0
#define freq 10.0
real y[ND_ND] ;
real x;
face_t f;
x = y[0];
best regards
Old   March 27, 2019, 07:28
dear AlexanderZ,
thank you very much for your help
to clarify the problem exists only in the part that represents the projection along the axis OY
#include "udf.h"
#include "math.h"
#define PI 3.14
#define A 20.0
#define freq 10.0
real y[ND_ND] ; /* projection along the OX axis */
real x;
face_t f;
real y[ND_ND]; /* projection along the OY axis */
real x;
face_t f;
x = y[0];
Best regards
Old   March 27, 2019, 20:34
Alexander
to clarify - no
best regards
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Problem with compiling UDF in Fluent amojodi Fluent UDF and Scheme Programming 4 April 14, 2015 10:01
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 05:06
