UDF for current particle position
Old   March 5, 2019, 20:25
Default UDF for current particle position
zyfantastic is on a distinguished road
Hi all,
I am trying to get the particle position in domain in a transient flow by UDF. I tried to use DEFINE_EXECUTE_AT_END so that I can get the position every time step. my code is as follows:
DEFINE_EXECUTE_AT_END(gpif)
Injection *Ilist;
Injection *I;
Particle *p;
Ilist = Get_dpm_injections();
FILE *fid1;
fid1 = fopen("particleposition.txt","w");
loop(I,Ilist)
loop(p, I->p_init)
fprintf(fid1, "%f %f %f %f %f %f %f %"int64_fmt"\n",P_POS(p)[0],P_POS(p)[1],P_POS(p)[2],P_VEL(p)[0],P_VEL(p)[1],P_VEL(p)[2],P_TIME(p),p->part_id);
fclose(fid1);
I can only get the initialization position of the particles.
if I change Particle *p to Tracked_Particle *p, the fluent just crashed.
Can someone help me to solve the problem please?
Thanks in advance.
zyFan
zyfantastic is offline   Reply With Quote
Old   March 5, 2019, 21:23
gearboy is on a distinguished road
Your code seems only prints the position of particles at injections. They will not be tracked at each iteration end. So error occurs. I suggest you use DPM macros, such as DEFINE_DPM_SCALAR_UPDATE(name,c,t,initialize,p), where p is just the Tracked_Particle * type given by Fluent.
Originally Posted by zyfantastic View Post
Hi all,
Injection *Ilist;
Injection *I;
Particle *p;
FILE *fid1;
loop(I,Ilist)
loop(p, I->p_init)
fclose(fid1);
Thanks in advance.
zyFan
gearboy is offline   Reply With Quote
Old   March 6, 2019, 02:22
Hi gearboy,
Thanks for your answer, I have tries the DEFINE_DPM_SCALAR_UPDATE(name,c,t,initialize,p). But it exported too many particle data information as the macros is called every time a particle position is update. If I set the condition if (P_TIME(p) == CURRENT_TIME), the code is as follows:
#include "udf.h"
#include "dpm.h"
DEFINE_DPM_SCALAR_UPDATE(gpif,c,t,initialize,p)
int n;
n = N_TIME;
char filename[50];
real current_time = CURRENT_TIME;
snprintf(filename,50,"particleposition_%d.txt",n);
FILE *fid1;
fid1 = fopen(filename,"a");
else
printf("time is not reached");
fclose(fid1);
I can`t get all particle data after 1st time step.
I need all particles position data at the end of each time step. Do you have any method to do it?
Thanks and regards,
zyFan
Particle cooling rate - UDF papteo Fluent UDF and Scheme Programming 9 January 29, 2012 10:28
Force dependent on particle position jranita OpenFOAM Programming & Development 1 August 23, 2011 20:44
UDF for Particle reaction and DPM_Property saifulraju ANSYS 0 September 22, 2010 08:24
udf about particle concentration--who can help me? zhaoh FLUENT 1 January 17, 2007 12:46
Help: UDF of "particle body force" !!! zhaoh FLUENT 3 January 16, 2007 21:17
