Using an UDF to consider the particle size in DPM
Old   February 28, 2019, 09:28
Default Using an UDF to consider the particle size in DPM
Liliana de Luca Xavier Augusto
liliana is on a distinguished road
Hi all,
I am simulating a situation where I have a particle travelling in a fluid. The gap where the fluid flows is too small, and the particle size became important in this case. Does anyone know how can I use an UDF to consider the particle size?
I would be an UDF to make the collision between the particle and the boundary when the distance between the "point" (particle in DPM) is equal or smaller than the diameter of the particle.
Thanks!
liliana is offline   Reply With Quote
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 03:03
Using UDF to alter particle size Tumppi Fluent UDF and Scheme Programming 7 February 28, 2019 09:27
IN dpm model,How to get the concentration of particle in a cell using udf turmon Fluent UDF and Scheme Programming 1 August 30, 2018 01:30
Particle size distribution DPM barzin FLUENT 8 January 25, 2016 06:15
DPM; particle seeded / deleted by UDF Laika FLUENT 6 January 23, 2006 00:40
