Difference between Macros for evaporation Mass Trnasfer |
February 26, 2019, 21:35 |
Mochibaru
Rep Power: 11 |
Good Morning Seniors,
Recently i am Modelling Evaporation with UDF using VOF. I found the following two Macros for the Calculating Mass transfer at Interface: 1. Add Mass and Energy Sources using 'DEFINE SOURCE' Macro and then hook up the sources udf from the source menu. In this case i am confused what i have to input the 'Phase Interaction Menu of VOF' 2. Can Use the " DEFINE_MASS_TRANSFER" and hook the udf in the Phase interaction menu of VOF. But in this case i am so confused that whether both the Energy and Mass Sources will be added in response to this macro or i have to add them seperatly. Thank you so much for your suggestion to remove confusion in the mind. By the way i have seen the UDF manual before writing this confusion here. Kind Regards, Khan |
June 23, 2019, 22:35 |
Soumitra Vadnerkar
Rep Power: 8 |
Can you guide me as well if you got your problem solved please?
Mass flow rate difference when using profiles | wimblo | FLUENT | 2 | April 23, 2018 11:42 |
How to fix difference in mass flow? | wadeellis | STAR-CCM+ | 6 | May 30, 2017 12:18 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Difference between Mass Flow Average in CFX and Mass-Weighted Average in Fluent | dasha | ANSYS | 0 | December 21, 2012 05:41 |
Mass error in finite difference codes | Kalyan | Main CFD Forum | 8 | August 30, 2000 06:16 |
