Setting a parameter as bound in a loop
Old   February 14, 2019, 12:10
Default Setting a parameter as bound in a loop
Frank Richter
FrankR is on a distinguished road
Dear Community,
I need Scheme for programming for ANSYS FLUENT.
How can I set a parameter
imax = 3
and then use it as upper bound in a loop:
(do ((i 1 (+ i 1)))((> i imax))
[do something here]
This loop is run repeatedly in my script, thus a single definition of the upper bound would be extremely helpful.
I experimented with the commands let and define, but to no avail.
Thank you dearly,
kind regards
FrankR
FrankR is offline   Reply With Quote
Old   February 14, 2019, 22:10
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
define your imax variable above this loop same way as you define any other rpvar
for example
(define (make-new-rpvar name default type)(if (not (rp-var-object name))(rp-var-define name default type #f)))
(make-new-rpvar 'imax 3 'int)
[do something here]
best regards
AlexanderZ is offline   Reply With Quote
Old   February 15, 2019, 04:55
Frank Richter
Dear AlexanderZ
thank you for your advice.
Sincerely
FrankR
loop, variable definition
question about fluid2 parameter setting Mike Wang FLOW-3D 1 November 3, 2017 04:41
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Expert Parameter for compressible transient ioannis CFX 0 November 2, 2005 20:28
CFX TASCflow - while-endwhile loop ina macro Deepak Ganga CFX 0 September 6, 2003 23:21
