February 12, 2019, 12:30 |
Field function name to be used into UDF
Rep Power: 11 |
I need to use a field function of Fluent (the pseudo local time step of the cell) inside an UDF, saving it into the variable C_UDMI(c,y,0) with a DEFINE_ADJUST function . However I don't know the variable name that refers to that field function. If I use the GUI and go to contour plot or if I use custom field functions the variable is located at the menu "Residual/time-step". How can I identify its name for the UDF's use? Thanks, WhiteW |
November 9, 2020, 09:06 |
Mostafa
Rep Power: 12 |
Dear WhiteW,
Did u get the answer to ur question? if yes, please share it here. Thanks in advance. BR, sasa |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 12:32 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
