February 11, 2019, 13:49 |
accessing C_VOF from EXECUTE_AT_END
RD
Rep Power: 8 |
I am trying to access C_VOF from EXECUTE_AT_END macro. I'm getting a fatal error when I run the solver. It is compiling fine. Can anybody help me? and I'm also confused with the zone id and domain id. here the udf: DEFINE_EXECUTE_AT_END(alpha) { Domain *d; Thread *t; Thread **pt; cell_t c; int zone_ID=1; Thread *mixture_thread = Lookup_Thread(d,zone_ID); pt = THREAD_SUB_THREADS(mixture_thread); d = Get_Domain(1); thread_loop_c(t,d) { begin_c_loop(c,t) { C_UDMI(c,t,0)= C_VOF(c,pt[1]); C_UDMI(c,t,1)= C_LIQF(c,pt[1]); } end_c_loop(c,t) } } |
February 11, 2019, 22:34 |
Alexander
Rep Power: 34 |
which model do you use for this simulation?
Multiphase? Solidification? You should explain in details if you wanna get help Do you know, that: C_LIQF is available only in fluid cells and only if solidification is turned ON best regards |
February 12, 2019, 05:14 |
RD
Rep Power: 8 |
Hi AlexanderZ,
I am trying to model melting of phase change material I have separate domain from geometry for air and pcm. I'm using VOF and melting/solidification model in fluent. I want to access the C_VOF and C_LIQF for both the domain( air and pcm). |
February 12, 2019, 22:48 |
Alexander
Rep Power: 34 |
what kind of error did you get?
did you defined 2 UDMs in FLuent GUI? best regards |
February 13, 2019, 09:35 |
RD
Rep Power: 8 |
Dear ALexandarZ,
I have specified UDMI in GUI. |
February 13, 2019, 09:37 |
RD
Rep Power: 8 |
I'm getting a segmentation fault when fluent iteration starts.
February 14, 2019, 00:39 |
Alexander
Rep Power: 34 |
i dont have much experience in multiphase simulations
may be Code:
int zone_ID=1; To check this value in fluent GUI go to Cell Zone Conditions, select fluid zone, you will get ID value there. put it in UDF best regards |
February 14, 2019, 00:48 |
RD
Rep Power: 8 |
Dear AlexanderZ,
Thanks for your response. I have checked with the zone ID and it worked. Thank you. |
Accessing data from sixDoFRigidBodyMotionState outside sixDoFRigidBodyMotion | Hannes_Kiel | OpenFOAM Programming & Development | 0 | March 28, 2015 09:41 |
accessing thermophysical properties on a lower level | romant | OpenFOAM Programming & Development | 4 | October 28, 2013 09:25 |
How to define a Macro accessing rad intensity | Grey | FLUENT | 0 | May 21, 2007 01:12 |
Problem accessing Temp. Gradient . . . | Satish | FLUENT | 16 | December 16, 2003 14:44 |
In UDF, accessing pressure value..urgent!! | prasanth | FLUENT | 2 | July 19, 2003 08:30 |
