How to create new macro?
Old   February 9, 2019, 14:03
Default How to create new macro?
Peter Maroul
Pmaroul is on a distinguished road
Hi all.
I saw into the previous forums a fairly strange user defined macro as follows:
int neighborcell(cell_t c, Thread *t, cell_t *cn, Thread **tn, int n).
This macro isn't defined in cell macros in UDF programming. That is probably defined for the first time by a user.
Hereby, One question comes up to me:
How can we define a new macro or function to be inserted in UDF programming?
Thanks in advance for any answer!
P.Maroul
Pmaroul is offline   Reply With Quote
Old   February 11, 2019, 02:29
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
same way as function in C language
best regards
AlexanderZ is offline   Reply With Quote
Old   February 11, 2019, 11:37
pakk will become famous soon enough
Originally Posted by Pmaroul View Post
Hi all.
P.Maroul
You gave an example of how to define a function.
And then you ask how to define a function...
You have answered your own question before you asked it!
pakk is offline   Reply With Quote
Old   February 11, 2019, 19:54
Peter Maroul
Thanks Sir.
Ok, but I indicated only a function title . My main question is that where and how to define or recall in macros.
For example, Is it essential to define it in UDF.h or can we define it everywhere in udf macros for example in define-adjust?
Old   February 11, 2019, 20:00
Peter Maroul
best regards
Thanks a lot.
Therefor, I can define some new functions before UDF macros and then using them in those macros. Isn't it?
Old   February 11, 2019, 22:29
Alexander
You are making things complicated.
Macros are build in fluent functions, nothing else. You cant modify them (may be can, but not recommended)
On the other hand, you may create file with your own function (or put these functions in your source file for each UDF). When you will compile your UDF hook this file with UDF source. Same as in C
best regards
Old   February 19, 2019, 06:08
Peter Maroul
Dear Alexander
Therefor, Can I write a file (for example file name: udfexample.c) with following structure? Is it correct?
/*  function commands here written*/
/*for example define_init*/
#include "udf.h"
DEFINE_INIT(my_init_func,d)
/* text commands here*/
Old   February 19, 2019, 06:12
Alexander
#include "udf.h"
in the first line
you should execute your function from one of Fluent macros. (for example from DEFINE_INIT)
best regards
Old   February 19, 2019, 06:20
Peter Maroul
How is the following one?
Is it true?
#include "udf.h"
{/* function definition immediately starts after define init calling*/
}/* The end of fuction definition*/
/*First lines of define _init after function definition */
Old   February 19, 2019, 22:34
Alexander
#include "udf.h"
// if you want execute your function:
neighborcell(c, t, cn, tn, n) // of course c , t , cn ,tn, n values should be defined
best regards
Old   February 20, 2019, 06:12
Peter Maroul
Dear Alexander
Your Answers was so helpful.
Thanks a lot for your kind attention.
P.Maroul
new macro creation
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[gmsh] How to create a 3D volume mesh using a existing surface mesh?! RobertHB Mesh Generation & Pre-Processing 0 July 20, 2017 09:12
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer seal2013 ANSYS Meshing & Geometry 3 October 6, 2013 17:09
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 05:18
