UDF for Thermodynamic property function of P and T
Old   February 4, 2019, 17:12
Default UDF for Thermodynamic property function of P and T
Fab
Federer83 is on a distinguished road
Hi guys,
I have created a thermodynamic database for my fluid function of P and T and i would like to use it in my FLUENT calculation.
I heard that in the past this was not possible in FLUENT. Is this problem being solved with the newest version?
If so, how can i write an UDF to run my simulation?
Many thanks in advance,
Federer83 is offline   Reply With Quote
Old   February 5, 2019, 06:02
pakk will become famous soon enough
Have you checked the Fluent help? It is practically there in the "Define_Property UDFs" section.
pakk is offline   Reply With Quote
Old   February 6, 2019, 12:32
Fab
Thanks Pakk. Yes I have checked the DEFINE_Property function, however i didnt get it if this could work also for the specific heat. I have a matrix for specific heat function of pressure and temperature and i would like to use it since my fluid is affected by big pressure an temperature drops. Do you know if it is possible?
Old   February 11, 2019, 01:45
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
for specific heat use DEFINE_SPECIFIC_HEAT macro
best regards
AlexanderZ is offline   Reply With Quote
Old   February 11, 2019, 09:03
Fab
Hi Alexanderz
Do you think i can set the cp function of the P and T with this function? I read that you can only specify the variation of the cP with T.
Old   February 11, 2019, 22:24
Alexander
I remember same information, only T. But you may try, it is not so difficult
best regards
Old   February 12, 2019, 05:41
SS
Bluewave is on a distinguished road
It's definitely possible using Define_Property macros. I have used it earlier to model high temperature transport properties using chapman-enskog method. You can try
Bluewave is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 11:05
[FLUENT] Loading UDF function problems Faggio11 FLUENT 0 August 9, 2016 07:33
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
