Creating an external file with data
Old   January 30, 2019, 18:00
Default Creating an external file with data
GenD
GenD is on a distinguished road
I'm trying to create an external file with data after each time step. To do this I use DEFINE_EXECUTE_AT_END macro, but I've some problems.
First of all, in the generated file, the only thing that is saving is the data for the last time step, but I want to have it for every one, so I suppose it just overwrites every time step. I thought I will omit this issue by using arrays, but I just can't get through with them. Could you please help me solve it?
Secondly, there happen to be another problem with macros for temperature (C_T(c,t)) and other, cause ANSYS says that there are no initialized variables of c and t, but in my code I have them.
I will put code in here.
Maybe whole idea is wrong? Could you please assist me with this?
#include "udf.h"
int i = 0;
real rho[10000];
real T[10000];
real velocity[10000];
real r_num[10000];
real time[10000];
DEFINE_EXECUTE_AT_END(write_file)
		Thread *t;
		cell_t c;
		T[i] = C_T(c, t);
		rho[i] = C_R(c, t);
		real mu = 0.001003;
		velocity[i] = C_V(c, t);
		real diameter = 0.038;
		r_num[i] = ((rho[i] * pow(diameter, 2) * velocity[i]) / mu);
		time[i] = CURRENT_TIME;
		FILE *fptr;
		fptr = fopen("example.txt", "w");
		fprintf(fptr, "Temperature       Density       Viscosity       Reynolds number       Time\n");
		fprintf(fptr, "%4.2f %4.2f %4.6f %4.2f %4.3f\n", T[i], rho[i], mu, r_num[i], time[i]);
		fclose(fptr);
		i++;
GenD is offline   Reply With Quote
Old   January 30, 2019, 21:30
gearboy is on a distinguished road
Originally Posted by GenD View Post
#include "udf.h"
int i = 0;
real rho[10000];
real T[10000];
real r_num[10000];
real time[10000];
        Thread *t;
        cell_t c;
        T[i] = C_T(c, t);
        rho[i] = C_R(c, t);
        real mu = 0.001003;
        FILE *fptr;
        fclose(fptr);
        i++;
You can use "append" flag instead of "overwrite" flag when opening a file.
fptr = fopen("example.txt", "a+");
gearboy is offline   Reply With Quote
Old   January 31, 2019, 20:05
GenD
Thank you gearboy. It really helped me.
Now, I struggle with the second problem. The code looks now like this.
#include "udf.h"
int i = 0;
real rho[10000];
real T[10000];
real r_num[10000];
real time[10000];
cell_t c;
Thread *t;
DEFINE_ON_DEMAND(on_demand_write)
	FILE *fptr;
	fclose(fptr);
DEFINE_EXECUTE_AT_END(write_file_at_end)
		T[i] = C_T(c, t);
		rho[i] = C_R(c, t);
		real mu = 0.001003;
		FILE *fptr;
		fclose(fptr);
		i++;
It compiles fine, without any error, but then after I start simulation, I got an error:
Node 0: Process 14620: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
I think it is connected with macros C_T(c, t), C_R(c, t) and C_V(c, t), because, when I put instead of those macros just some numbers, it works fine. Do you have any idea, how to solve this?
Old   February 1, 2019, 05:11
#include "udf.h"
int i = 0;
real rho[10000];
real T[10000];
real r_num[10000];
real time[10000];
cell_t c;
Thread *t;
    FILE *fptr;
    fclose(fptr);
        T[i] = C_T(c, t);
        rho[i] = C_R(c, t);
        real mu = 0.001003;
        FILE *fptr;
        fclose(fptr);
        i++;
For the confusing errors, you have to debug and trace the code step by step.
Old   February 1, 2019, 07:36
GenD
Yes, that's exactly what I've done and it proved that a problem is with macros C_T(c, t), C_R(c, t) and C_V(c, t), and I don't know why. Does anyone know the reason?
Old   February 2, 2019, 08:25
GenD
I've been working to make UDF work by the use of Customization Manual and cases written in all kinds of forums and I've developed a code. BUT it does not work for me, what is funny because the errors are with macros. I've tried to replace macros (C_T(c,t), C_R(c,t), C_V(c,t), C_VOLUME(c,t) ) with number 1 and it worked properly, so i don't get how to omit this. Actual version of the code is below, so if somebody knows the issue, I will be glad if you help me.
In addition I can say that I've tried to use final, proper codes from forums and Customization Manual connected with macros given above and those didn't work too.
#include "udf.h"
cell_t c;
Thread *t;
Domain *d;
	real vol_tot = 0;
	real volume = 0;
	real mu = 0;
	real rho = 0;
	real T = 0;
	real velocity = 0;
	real r_num = 0;
	real time = 0;
	real Tavg = 0;
	real rhoavg = 0;
	real velavg = 0;
	d = Get_Domain(1);
	int thread_num = 6;
	t = Lookup_Thread(d, thread_num);
	thread_loop_c(t, d)
		begin_c_loop(c, t)
			T = C_T(c, t);
			rho = C_R(c, t);
			velocity = C_V(c, t);
			time = CURRENT_TIME;
			volume = C_VOLUME(c, t);
			vol_tot += volume;
			Tavg += T * volume;
			rhoavg += rho * volume;
			velavg += velocity * volume;
		end_c_loop(c, t)
		Tavg /= vol_tot;
		rhoavg /= vol_tot;
		velavg /= vol_tot;
		mu = 0.001003;
		r_num = ((rhoavg * pow(diameter, 2) * velavg) / mu);
		FILE *fptr;
		fprintf(fptr, "%4.2f                 %4.2f        %4.6f              %4.2f            %4.3f\n", Tavg, rhoavg, mu, r_num, time);
		fclose(fptr);
	FILE *fptr;
	fclose(fptr);
Old   February 4, 2019, 11:22
pakk will become famous soon enough
You replaced macros C_T(c,t), C_R(c,t), C_V(c,t) and C_VOLUME(c,t) with number 1, and it worked.
Did you try to replace macros C_T(c,t) and C_R(c,t) with one (so leaving C_V(c,t) and C_VOLUME(c,t))?
If that gives no error, you know the problem is in C_T or C_R.
If so, try only C_T.
And make sure (double sure) that you initialize your data before you run this macro.
pakk is offline   Reply With Quote
Old   February 7, 2019, 16:14
GenD
I've applied your plan of troubleshooting and as a result I got that C_T(c, t) (so temperature) is a problem. Any other like macros for density, volume, etc. work well. Do you have any idea, why is that?
Yes, of course I initialize data before calculations. It is impossible do to so without it.
execute at end, external file, udf
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
