UDF: problem with calculating velocity gradient to normal direction |
January 15, 2019, 03:29 |
Ho Kam Dai
Recently, I am doing a project related to a pipe structure and I need to do some modification to the surface shear stress, so I need to access the velocity gradient to the normal direction for the purpose. Since the structure is something similar to a circular pipe, C_V_G(c,t),C_U_G(c,t) and C_W_G(c,t) would not directly access what I need. Is there any thoughts or suggestion that can help me out of this problem? |
Surface normal velocity BC with zero gradient tangential, cylinder | c_dowd | OpenFOAM Running, Solving & CFD | 0 | May 25, 2013 08:22 |
Multi step transient UDF velocity profile problem | William177 | FLUENT | 1 | February 3, 2008 07:47 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 16:57 |
the problem of UDF | zzb | FLUENT | 2 | April 5, 2006 06:36 |
problem for UDF velocity | Geremi | FLUENT | 0 | April 19, 2005 03:13 |
