Writing first UDF
Old   January 7, 2019, 13:29
Default Writing first UDF
Max
max.kozak is on a distinguished road
Hello All,
I need to write a UDF for monitoring a species mass fraction, which I believe should be pretty simple. However, I don't have any experience coding, so I'm hoping I can get some guidance to get started.
Essentially, I have a UDS set up for a species as a certain inlet mass fraction, and I want to include a species death rate as a function of first order kinetics. I have used data to determine this correlation, along with a k constant, but I do not know how to include this in a UDF. Does anyone have any advice or resources that can point me in the right direction for someone without any coding experience?
I greatly appreciate any help.
max.kozak is offline   Reply With Quote
Old   January 8, 2019, 11:38
pakk will become famous soon enough
You basically want the UDS to be removed from your volume (in a controlled way). So, essentially you want a sink.
A sink is a negative source.
So look at DEFINE_SOURCE in the Fluent manual (Fluent customization Manual, section 2.3.36).
pakk is offline   Reply With Quote
Old   January 15, 2019, 15:01
Max
Thanks so much for your reply pakk. I've written some code using the DEFINE_SOURCE macro, and it's saying that I'm missing parameters for this macro. Here's what I have so far...
#include "udf.h"
DEFINE_SOURCE(cell_deathrate,c,t,i)
real source;
real k;
k=0.0000108840
source=-k*C_UDSI(c,t,0);
return source;
Basically, I want to monitor this UDS as dN/dt = -k*(local cell concentration). I thought this would do the trick to set up the first order kinetics and add a sink, but I continue to get some errors. Do you have any insight into what I may be missing? Thanks so much.
Old   January 16, 2019, 05:59
#include "udf.h"
real source;
real k;
k=0.0000108840
return source;
It's difficult to solve the errors, because I can not see which errors you get.
first order, species mass fraction, udf code
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Writing UDF to represent drag equations Dawood Al-Mosuli FLUENT 1 April 27, 2015 06:02
Seek help in writing UDF Jack Martinez FLUENT 9 June 14, 2007 11:24
New to writing UDF Sandilya FLUENT 0 May 31, 2007 13:03
