Cannot interpret UDF! parse error!?
Old   January 5, 2019, 05:47
Question Cannot interpret UDF! parse error!?
Roh
Roh is on a distinguished road
Guys,
Just tried to interpret my UDF But don't know why I get this error:
cpp -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/main" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/addon-wrapper" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/io" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/species" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/pbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/numerics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/sphysics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/storage" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mphase" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/bc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/models" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/material" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/amg" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/util" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mesh" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/udf" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ht" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dx" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/turbulence" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/parallel" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/etc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ue" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dpm" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/PRIME/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "F:/RD/RDUDF.c" Error: F:/RD/RDUDF.c: line 1: parse error.
What's the problem?
Roh is offline   Reply With Quote
Old   January 7, 2019, 00:09
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
put
#include "udf.h"
as the first line.
put here your UDF if you want to get help
best regards
AlexanderZ is offline   Reply With Quote
Old   January 8, 2019, 11:33
pakk will become famous soon enough
"Parse error" means that Fluent can not parse (understand) the code that you give to Fluent. So the problem is in your code. If you want help, share the code, we can not guess what your code is.
(Although AlexanderZ probably guessed correctly, there could still be other problems with your code.)
pakk is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
