DEFINE_CHEM_STEP reaction heat
Old   January 2, 2019, 08:46
Default DEFINE_CHEM_STEP reaction heat
CFDJonas is on a distinguished road
Hello everyone,
I finally managed to get my reaction system going with the DEFINE_CHEM_STEP macro (see below). Although the mass fractions of the species are correct, I no longer see a generation of heat. The temperature profile of a converged simulation states a constant temperature of e.g. 500 K. Although my mixture has indeed different enthalpys set for the species (which are produced/consumed). Where/How do I handle reaction enthalpies when dealing with DEFINE_CHEM_STEP?
I'm using Fluent 19.2 with some other custom udf (viscosity, heat capacity, thermal conductivity and density of the mixture, although these are throughly tested).
DEFINE_CHEM_STEP(chem_steps, c, t, p, num_p, n_spe, dt, pres, temp, yk)
	real ck[N_COMP];
	real rates[N_COMP];
	real pres_bar = *pres / 1e5; // bar
	real rho = C_R(c, t);
	// Get concentrations from mass fractions
	for (i = 0; i < N_COMP; i++)
		ck[i] = rho * yk[i] / M_i[i];
	// Calculate the rates
	rates[i_example_species] = -k_exp * ck[i_example_species];
        // etc.
		ck[i] += rates[i] * *dt;
		yk[i] = ck[i] * M_i[i] / rho;
		// Message("\n Specie %d = %f \t TimeStep = %e", i, yk[i], *dt);
Thanks in advance!
CFDJonas is offline   Reply With Quote
Old   May 2, 2020, 12:13
Di Cheng
chengdi is on a distinguished road
Did you enabled the energy equation?
chengdi is offline   Reply With Quote
Old   December 15, 2021, 05:01
Jinshan Yi
study_CFD is on a distinguished road
I also encountered the same problem. Have you solved it?
study_CFD is offline   Reply With Quote
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 22:42
UDF to access quantity of heat absorbed by one phase in Multi phase reaction process Yuting FLUENT 0 March 15, 2017 23:52
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Reaction heat Laci FLUENT 2 July 23, 2009 03:03
heat of reaction Paul FLUENT 4 August 7, 2003 12:58
