Passing values to reference values from UDF
Old   December 27, 2018, 15:24
Post Passing values to reference values from UDF
Mohamed Saied Sayed
mohamed_abdelgawad is on a distinguished road
Hello everyone
I am simulating a re-entry vehicle at hypersonic speed and high altitude (80 KM). I use a UDF to calculate the pressure profile and using ideal gas. I use transient solver.
So the question I would like to ask you is:
How to pass the calculated pressure value from the UDF to apply at the REFERENCE VALUES at each time step?
Thanks
mohamed_abdelgawad is offline   Reply With Quote
Old   December 28, 2018, 11:37
RCamp is on a distinguished road
Do you want the reference values to be used in your next calculation of your UDF or do you mean the reference values Ansys uses for post processing?
RCamp is offline   Reply With Quote
Old   December 28, 2018, 12:12
Mohamed Saied Sayed
I want the calculated pressure value from the udf to be set to the reference value for the next post processing
Old   December 28, 2018, 12:14
Mohamed Saied Sayed
Simply we can say that the reference values doesn’t update according to the calculated values from the UDF and i want to ubdate it every time step
Old   December 28, 2018, 13:18
Okay and which DEFINE Marco are you using ?
Old   December 28, 2018, 13:26
Mohamed Saied Sayed
DEFINE_PROFILE(pr_mag, thread, position)
Old   December 30, 2018, 20:43
I am not sure if there’s a very direct way to do this. You might want to look into DEFINE_EXECUTE_AT_END.
Old   December 30, 2018, 22:24
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
As RCamp mention you should use DEFINE_EXECUTE_AT_END macro, if you want to make calculation after timestep. DEFINE_PROFILE is macro to set boundary condition.
about your first question:
What is your exact question, are you just lazy to set reference values manually, if yes, it means you don't really need to update it on each timestep. In that case you may create scheme file, which will read some value from your UDF and apply it to reference value:
1. using TUI command you may apply reference value. Type in fluent console
" report reference-values pressure *SOME VALUE* "
2. workflow:
- create variable in scheme
- calculate pressure in UDF
- set scheme variable value
- execute scheme file, which will run TUI command, using scheme variable value with reference pressure
best regards
AlexanderZ is offline   Reply With Quote
Old   December 31, 2018, 09:09
Mohamed Saied Sayed
Hello Alexander
Thanks for your help but my reference variables change every time step according to the calculated values from the UDF so if you have a code that can do that i will be so thankful
reference -values, udf
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Periodic (rotational)flow: a bit of confusion concerning reference values Mr.Goodcat FLUENT 0 March 22, 2016 08:31
compile error about FJMPI chiven OpenFOAM Installation 11 March 31, 2010 07:27
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
