DEFINE_NET_REACTION_RATE problem
Old   December 21, 2018, 05:47
Default DEFINE_NET_REACTION_RATE problem
CFDJonas is on a distinguished road
Hello everyone again,
I'm trying to switch to the stiff chemistry solver, thus my understanding is I have to swtich from DEFINE_VR_RATE to DEFINE_NET_REACTION_RATE (or DEFINE_CHEM_STEP). My problem is, when I hook the DEFINE_NET_REACTION_RATE the solver interrups even before going into the UDF once, because of a "Non-physical Specific Heat = 0.000000e+00". Even when I set the rate for each species to zero/or have a Message output in the first line of this UDF, nothing happens.
I also tried to achieve my goal by using the DEFINE_CHEM_STEP but then I have to assign new mass fracs. This is a little bit inconvinient as my rates are molar rates. However I managed to get some kind of result by calculating the concentration, calculating the rate, and then adding up the rate*CURRENT_TIMESTEP to the last concentration and then convert back to a mass fraction. However this does not deliver correct results (the CURRENT_TIMESTEP is always 1 so this multiplication is kinda weird to me).
Does anybody have a little bit of experience about chemistry using the stiff chemistry solver? I really don't know how to approach this problem.
CFDJonas is offline   Reply With Quote
Old   December 15, 2021, 20:58
Jinshan Yi
study_CFD is on a distinguished road
Have you solved it? I have a similar problem
study_CFD is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
