I have a contour display problem need some help... |
December 19, 2018, 11:00 |
Lee JP
Rep Power: 8 |
I was simulating the separate flow over the sandwave using SST k-w modeling.
As you can see, I wrote an udf in order to calculate the shear-stress and shear-velocity inside the fluid, the compiling process and loading were ok, calculating is also fine, the problem occurs when I display the User Memory 0 and 1. They are separately shear-stress and shear-velocity, but the contour of the shear-velocity apparently has some problem. I had tried change the options in view menu but it doesn't work. 78c6595105cc19b81c12cd2a2437e6c.jpg Clip_20181219_225447.png The code I wrote is as follows. If you had met a similar problem as I do please let me know how you solve it, or any suggestion is also welcome! Thank you! #include "udf.h" #include "mem.h" #include "sg_udms.h" #define rho 998.2 #define g 9.81 #define wl 0.046 /* #define NUM_UDM 2 */ // static int offset = UDM_UNRESERVED; DEFINE_PROFILE(vof_profile, t, i) { #if !RP_HOST real x[ND_ND]; face_t f; begin_f_loop(f, t) { F_CENTROID(x, f, t); if (x[1] <= wl) { F_PROFILE(f, t, i) = 1; } else { F_PROFILE(f, t, i) = 0; } } end_f_loop(f, t) #endif } DEFINE_PROFILE(outlet_pressure, t, i) { #if !RP_HOST real x[ND_ND]; face_t f; begin_f_loop(f, t) { F_CENTROID(x, f, t); if (x[1] >= wl) { F_PROFILE(f, t, i) = 0.0; } else { F_PROFILE(f, t, i) = rho*g*(wl-x[1]); } end_f_loop(f, t) } #endif } DEFINE_PROFILE(inlet_velocity, t, i) { #if !RP_HOST real x[ND_ND]; face_t f; begin_f_loop(f, t) { F_CENTROID(x, f, t); if (x[1] > wl) { F_PROFILE(f, t, i) = 0.0; } else { F_PROFILE(f, t, i) = 0.21; } end_f_loop(f, t) } #endif } /*DEFINE_EXECUTE_ON_LOADING(on_loading, libname) { offset = Reserve_User_Memory_Vars(NUM_UDM); Set_User_Memory_Name(offset, "shear-stress"); Set_User_Memory_Name(offset+1, "shear-velocity"); } */ DEFINE_EXECUTE_AT_END(calculate_shear_scales) { #if !RP_HOST Domain *d; Thread *t; cell_t c; d = Get_Domain(3); /* The id of the water domain in multiphase case */ thread_loop_c(t, d) { begin_c_loop(c, t) { C_UDMI(c, t, 0) = C_MU_EFF(c, t)*(C_DUDY(c, t)+C_DVDX(c, t)); C_UDMI(c, t, 1) = sqrt(C_UDMI(c, t, 0)/C_R(c, t)); } end_c_loop(c, t) } #endif } |
December 20, 2018, 00:33 |
Alexander
Rep Power: 34 |
what kind of problem do you have?
what's wrong with velocities? best regards |
December 20, 2018, 00:57 |
#3 | |
Lee JP
Rep Power: 8 |
I mean isn't there should be a full mapping with the contour display? But my first picture shows that there is some "empty data" or display mistake happen, how could I fix this or it is the right displaying? But it makes no sense right? |
contour display, some black points | frank | FLUENT | 3 | December 15, 2020 13:25 |
Problem with extracting data from contour in matlab | mihirmakwana6 | Main CFD Forum | 6 | August 5, 2015 18:43 |
CFX Contour (Problem in displaying contours) | ali8500 | CFX | 2 | January 2, 2012 17:21 |
DPM uncoupled display problem | K. Jagus | FLUENT | 0 | July 7, 2005 04:06 |
Problem about contour | LQ | CFX | 4 | July 2, 2005 22:57 |
