December 6, 2018, 17:12 |
average temperature of a face
on
Rep Power: 7 |
Hello all,
I am trying to find the average temperature of a face of a cube which is going to be used as inlet temperature to another domain. I am modelling a cube of stagnant water with inlet boundary condition at 323K. The output of my udf to calculate average temperature is coming zero! DEFINE_ADJUST(avg_temp,d) /*calc outlet temp average of water*/ { real tavg=0.0; face_t f; real A[ND_ND]; real area = 0.0; real area_tot = 0.0; Thread *t = Lookup_Thread(d,7); begin_f_loop(f,t) { F_AREA(A,f,t); area = NV_MAG(A); area_tot+=area; tavg+=F_T(f,t)*AREA; } end_f_loop(f,t) tavg/=area_tot; printf("avergae temperature of outlet of water is %f\n", tavg); printf("area total = %f\n", area_tot); } I am new to udf and would appreciate any help with this udf. Thank you! |
December 6, 2018, 19:21 |
Rep Power: 12 |
Hi Smukh,
Assuming you've pasted your code accurately, the first error to look at is tavg+=F_T(f,t)*AREA; because "AREA" is not the same as "area". (C language is case-sensitive.) This should not get past a compiler without some warnings, or maybe errors. Please can you debug this and tell us what happens next? Does your code report a sensible value of area_tot? This UDF is suitable only for serial Fluent, of course. I would discourage use of "printf" in UDFs -- "Message" is safer. The difference is possibly small, but not necessarily. Good luck! Ed |
December 10, 2018, 15:57 |
on
Rep Power: 7 |
Hi Ed,
Thank you for your suggestions. I have successfully resolved it. It worked when I changed from DEFINE_ADJUST to DEFINE_EXCUTE_AT_END and AREA to area. I am not sure why I wasn't getting the value even after changing caps area, it was giving me no error while compiling. But as I did not need values for every iteration I was fine by replacing adjust by at end. |
fluent - udf, fluent 18.0, temperature average value, udf code |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
Atributting one face temperature to another face | nfspetronilho | FLUENT | 0 | March 28, 2011 12:13 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
