I have a problem with UDF importing .dat datas. |
November 16, 2018, 08:06 |
UDF-Fluent debug on Ubuntu.
Rep Power: 8 |
Good morning,
I'm working with Ansys Fluent and the UDFs on Ubuntu. Is there an efficient way to debug a code? I've already tried those two guides: 1) https://www.cfd-online.com/Wiki/Udf_debug The point is that I can't debug my code efficiently. For example when the software is showing to me a segmentation fault the gdb is just 'segmentation fault' as show in the attachment below. So, I can't see which variable has problems. And is there a useful meaning on the number 0x00007fdada76afb7 that you can also see in the attachment? 2) [UDF compiling/debug]an integrated tool to edit/compile/debug UDF in Visual Studio Is this tool also working on Ubuntu? I've installed it with Wine, but it seems like I can't charge my VC version and my Fluent version to run on Ubuntu. Is there a way to debug an UDF that shows also where is the problem? Or is there a way to show where is the problem following the previous guides? Thank you for any help. Last edited by pianaCFD; November 25, 2018 at 07:17. |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 07:05 |
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. | Ari | Fluent UDF and Scheme Programming | 4 | May 31, 2016 09:51 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 01:53 |
udf loading problem | santu | Fluent UDF and Scheme Programming | 1 | May 22, 2015 16:47 |
Vaporization pressure UDF property problem? | lehoanganh07 | Fluent UDF and Scheme Programming | 1 | September 13, 2014 11:59 |
