November 1, 2018, 23:39 |
Air water interface velocity couple
MA
Hi guys!
I am working on coupling velocity at air-water interface in Microchannel. I want to make sure the velocity in air at the boundary is same as the velocity in water at the boundary. I defined the air-water interface as two walls(one face air with id 1 and one face water with id 2). Then I defined wall 1 as a moving wall(velocity defined by udf), wall 2 is shear free. But I need to access cells in water, which is out of current udf thread. Please help me, thank you! |
high air velocity at interface in interFoam | ufocfd | OpenFOAM Running, Solving & CFD | 3 | May 6, 2019 07:52 |
(interfoam) shear stress at water air interface ! | openfoam1 | OpenFOAM | 11 | October 27, 2014 04:59 |
Boundary condition of velocity and pressure at interface for air water pipe flow | jignesh_thaker2007 | OpenFOAM Running, Solving & CFD | 7 | June 19, 2014 11:12 |
Boundary condition of velocity and pressure at interface for air water pipe flow | jignesh_thaker2007 | OpenFOAM Running, Solving & CFD | 0 | June 10, 2014 17:42 |
Heat Transfer Coeff on the water air interface | Anton | Main CFD Forum | 3 | June 2, 2010 02:49 |
