Error while initializing a problem with a multi macro udf |
November 1, 2018, 11:24 |
Saurabh Das
Rep Power: 8 |
I wrote an udf which has several macros defining heat source, thermal conductivity, density and specific heat. (All thermophysical properties depend on temperature) Earlier, I solved the same problem, but with only the heat source macro, Fluent had no problem solving it. But as soon as I add another macro, the following error shows up How do I solve this? |
November 1, 2018, 20:37 |
Alexander
Rep Power: 34 |
when this error comes out?
if you want to get answer, you should describe in details best regards |
November 1, 2018, 23:30 |
Saurabh Das
Rep Power: 8 |
This error appears when I initialize the solution, and sorry for not mentioning it earlier, i thought the 'Initialize' screen on the pic would have been enough..
fluent - udf, mpi error |
Problem using UDF for velocity inlet | panasonic18 | Fluent UDF and Scheme Programming | 2 | June 13, 2018 02:59 |
UDF Parse Error - Initializing VOF for Multiphase Simulation | denbjornen | Fluent UDF and Scheme Programming | 0 | April 25, 2018 02:07 |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Problem loading UDF in Linux environment | hjan23 | FLUENT | 0 | December 15, 2017 04:09 |
UDF Problem about Grid Motion !!! | Zhengyu Gao | Fluent UDF and Scheme Programming | 0 | December 6, 2013 19:45 |
