UDF checks
Old   October 30, 2018, 03:39
Default UDF checks
Ki Jong Kim
denis Kim is on a distinguished road
hope all is well.
I am a new to the Fluent.
Now i am trying to analysis for sloshing.
But problem happened to me. Tho cylinder motion is quite difficult for me.
the motion for the cylinder is sinusoidal motion towards only one way (x-dir only)with +-40mm, 4hz.
Below is the UDF that i written.
Thank you much in advance.
#include "udf.h"
DEFINE_CG_MOTION(tank_mov, dt, vel, omega, time, dtime)
real a, w, pi;
pi = 3.1415;
/* define motion variables */
a = 0.04; /* 0.04m movement amplitude */
w = 2 * pi * 4; /* 4Hz frequency */
/* define object movement law */
vel[0] = a * w * sin(w*time);
vel[1] = 0;
vel[2] = 0;
denis Kim is offline   Reply With Quote
Old   October 30, 2018, 09:02
obscureed is on a distinguished road
Hi Denis,
This looks almost correct to me, except that "vel[0] = a * w * sin(w*time);" will give an amplitude "a * w". I think you intended to write "vel[0] = a * sin(w*time);".
Apart from that, it should be OK. Remember to save .cas and .dat files before you start any Moving/Deforming Mesh case. Use an appropriately small timestep. For a long time, there was a bug in Fluent that crashed when MDM cases with UDFs were closed and reopened -- so use a recent version of Fluent, where it has been fixed.
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   October 30, 2018, 09:29
Ki Jong Kim
Originally Posted by obscureed View Post
Hi Denis,
Good luck!
Ed
Many thanks to obscureed,
I tried once again, below message poped up.
Is there any problem this UDF?
Please help me..
test2.c
# Generating udf_names.c because of makefile test2.obj
udf_names.c
# Linking libudf.dll because of user_nt.udf udf_names.obj test2.obj
Microsoft (R) Incremental Linker Version 14.00.24215.1
Copyright (C) Microsoft Corporation. All rights reserved.
LINK : fatal error LNK1104: cannot open file 'libudf.dll'
Done.
Old   October 30, 2018, 09:33
Smile
Ki Jong Kim
Also, what is meaning of "Remember to save .cas and .dat files before you start any Moving/Deforming Mesh case."
Old   October 30, 2018, 20:37
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
this error means that you are trying to modify library, which is in use (you have loaded your UDF library in fluent) So you should unload first, than compile.
Best regards
AlexanderZ is offline   Reply With Quote
Old   October 30, 2018, 20:38
Alexander
File -> write -> case & data
best regards
Old   November 1, 2018, 00:04
Ki Jong Kim
best regards
Many thanks!!!alexanderZ
best wishes,
Kim
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
