October 18, 2018, 06:33 |
execute command
Rep Power: 9 |
hi dear
how can I write case & data by udf in fluent? because a parameter must be satisfied in udf and after that case and data write please help thanks |
October 18, 2018, 10:40 |
Rep Power: 27 |
The correct tool for this is not a UDF, but a scheme script, maybe in combination with a udf.
The Fluent manual has a section "37.16.5 execute commands dialog box". You add one command, and let it execute after every iteration. The make a macro that checks the parameter and saves your files if necessary. This is the difficult part, I have no real experience with this. |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 12:37 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 05:41 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
