UDF for electric coalescence
Old   October 9, 2018, 10:13
Default UDF for electric coalescence
liwenlong
leewenlong is on a distinguished road
PBM!!!! I want to write an UDF for electric coalescence kernel function. The equations
and UDF code are as follow. But someting is wrong with the code. Please help me to correct them.
Thank you for your attention.
DEFINE_PB_COALESCENCE_RATE(aggregation_kernel, c, t, d_1, t_2, d_2)
real f_1, f_2, lamuta, alpha, miu_ratio = miu_1/miu_2, agg;/*miu_1 and 2 are viscosity for two phases.*/
if (d_1>d_2)
lamuta = d_2/d_1, alpha = d_1;
else
lamuta = d_1/d_2, alpha = d_2;
f_1 = 2250*(miu_ratio+1)*pow(alpha,2)*(1-pow(lamuta,2))/(0.151263*miu_ratio+0.100842);
f_2 = 2.8*3*(1-lamuta)*pow(UM4,2)/(2*9.8*lamuta*114.8*alpha);
zhang_agg = 0.785*pow(d_1+d_2,2)*f_1*0.45*pow(f_2,0.55);
return agg;
leewenlong is offline   Reply With Quote
Old   October 9, 2018, 10:17
liwenlong
PLEASE not consider the case in absence of electric field. And the paper is attached. http://dx.doi.org/10.1016/j.jtice.2015.06.028
Old   October 9, 2018, 22:34
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what is wrong?
best regards
AlexanderZ is offline   Reply With Quote
Old   October 9, 2018, 23:12
liwenlong
I do not know where and why was wrong with it. the code can run in fluent. but the results are incorrect. thank you for your reply!
Old   October 10, 2018, 23:04
Alexander
take a look into your code
if (d_1>d_2)
else
from my point of view should be:
if (d_1>d_2)
{lamuta = d_2/d_1; alpha = d_1;}
else
{lamuta = d_1/d_2; alpha = d_2;}
may be this will help. You should compile this code.
best regards
pbm model udf
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
