September 26, 2018, 13:15 |
UDF for zero pressure gradient at BC outlet
Alessandro
Hi everyone! I'm a quite new user with Fluent and tried for several days to create an UDF for my case without success. I'll explain it:
I have an airbox with an inlet and two different outlets, the discharge (small) one and the main (big) one. Time steady, pressure based. In the small one I have to set this Boundary Condition: Pressure =0 (atmospheric pressure) and Velocity gradient = 0. But if I've correctly understand reading other threads here, Velocity gradient in all inlet and outlet BCs is always set to 0 by default, so in this outlet I should just choose the Pressure outlet BC and set gauge pressure = 0 right? In the big pressure outlet instead I've to set zero gradient for both velocity and pressure so, for the assumption made before, I've to write and UDF just for zero pressure gradient. I've made several up to this: Code:
/*****outlet BC - zero pressure gradient*****/ #include "udf.h" DEFINE_PROFILE(outlet_pressure_big, thread, position) { face_t f; real t = CURRENT_TIME; float C_P_G(c,t)[2]; C_P_G(c,t)[2] = 0; begin_f_loop(f,thread) { F_PROFILE(f, thread, position) = C_P_G(c,t)[2]; } end_f_loop(f, thread) line 8: parse error. -in the line float C_P_G(c,t)[2];- line 9: invalid type conversion: float -> pointer to char. -in the line C_P_G(c,t)[2] = 0;- Probably the solution will be very easy but since I'm still a newbie with Fluent in this moment i can't figure it out myself, I'd really appreciate your help, thanks! |
April 28, 2022, 06:12 |
subhankar
Rep Power: 10 |
Hi Alessandro,
I am also stuck in a similar problem. How were you able to give the zero pressure gradient condition at the outlet? Thank you Subhankar |
gradient at boundary, gradient boundary, pressure, udf |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
how to put udf inlet velocity and udf outlet pressure in fluent | raminostadi | Fluent UDF and Scheme Programming | 4 | July 3, 2017 07:43 |
Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 11:19 |
UDF for species-mass-fraction gradient at outlet | sisir | FLUENT | 0 | June 9, 2007 03:40 |
UDF in Fluent to Match Mass Flow at Pressure Outlet | Jonas Larsson | Main CFD Forum | 1 | April 29, 1999 11:44 |
