September 26, 2018, 00:39 |
"a variable = C_UDMI(c,t,0)" does not work.
JEONGMIN LEE
Lift force on bubble is Zero in this macro. Other variables to compute "FL" have their own numbers. Not zero.
I have no idea why "FL" goes to zero on each cell. C_UDMI problem? Would you give me any advices to fix this issue? Thanks in advance. -------------------------------------------------------------------------------------- DEFINE_SOURCE(Lift,c,tc,dS,eqn) { real source; real sum_vv; real sum_fa_top; real sum_fa_bot; real Re; real CL; real sum_fa; real Gs; real FL; real db; real M; real xc[ND_ND]; real mu = 3.994e-4; real Uz = 1.4; real rho = 1615; sum_vv = C_UDMI(c,tc,0); sum_fa_top = C_UDMI(c,tc,1); sum_fa_bot = C_UDMI(c,tc,2); sum_fa = sum_fa_top + sum_fa_bot; Thread **pt = THREAD_SUB_THREADS(tc); Thread *ts = pt[1]; if(sum_vv > 0. && sum_fa > 0.) { if(C_VOF(c,ts) >= 0.5) { db = sum_vv/sum_fa; printf("db: %e\n", db); Re = rho*C_W(c,tc)*db/mu; printf("Re: %e\n", Re); Gs = fabs(C_DWDY(c,tc))*db/2/C_W(c,tc); printf("Gs: %e\n", Gs); M = 1/(pow(Re,2))+0.014*pow(Gs,2); printf("M: %e\n", M); CL = 3.877*pow(Gs,1/2)*pow(M,1/4); printf("CL: %e\n", CL); FL = 3/4*CL*rho*C_W(c,tc)*C_W(c,tc)/db; -----> !!! ISSUE printf("FL: %e\n", FL); C_CENTROID(xc,c,tc); if(xc[1] < 0.0025) { source = FL; dS[eqn] = 0; printf("positive: %e\n", source); } else if(xc[1] > 0.0025) { source = -FL; dS[eqn] = 0; printf("negative: %e\n", source); } else { printf("nothing"); source = 0; dS[eqn] = 0; } } } return source; } Last edited by jm86groove; September 26, 2018 at 01:59. |
October 1, 2018, 04:13 |
Alexander
Rep Power: 34 |
did you define your UDMIs before calculation?
best regards |
October 5, 2018, 14:33 |
Rep Power: 12 |
Hi jm86groove,
If you think that FL should not be zero, but you get answers that suggest it is, then you can start debugging by printing details: Code:
FL = 3/4*CL*rho*C_W(c,tc)*C_W(c,tc)/db; if(fabs(FL)<1e-6) { Message("Bah! FL is near zero again: %g\n",FL); Message(" CL=%g, rho=%g, C_W=%g, db=%g\n",CL,rho,C_W,db); /* and eventually you become paranoid: */ Message(" 3/4 = %g\n",3/4); /* This might well give zero!!!!! */ Message(" 3./4. = %g\n",3./4.); Message(" 3./4.*CL = %g\n",3./4.*CL); Message(" 3./4.*CL*rho = %g\n",3./4.*CL*rho); Message(" 3./4.*CL*rho*C_W(c,tc) = %g\n",3./4.*CL*rho*C_W(c,tc)); Message(" 3./4.*CL*rho*C_W(c,tc)*C_W(c,tc) = %g\n",3./4.*CL*rho*C_W(c,tc)*C_W(c,tc)); Message(" 3./4.*CL*rho*C_W(c,tc)*C_W(c,tc)/db = %g\n",3./4.*CL*rho*C_W(c,tc)*C_W(c,tc)/db); } |
October 5, 2018, 14:46 |
Rep Power: 12 |
If the model is large and that gives an overwhelming amount of text to the screen, you can select some cells arbitrarily: replace
if(fabs(FL)<1e-6) { Code:
if(c%10000==1234 && fabs(FL)<1e-6) { A couple of points: -- I would advise always using Message rather than printf. -- Integer division rounds to the nearest integer, so there is always a risk that "3/4" is calculated to be "0" before it starts being floating-point. The same applies where you have typed "1/2" and "1/4" -- you should never type this! "1./2." is better, and "0.5" is better still. And "sqrt(Gs)" is probably quicker than "pow(Gs,0.5)", but speed is less important than correctness. -- I picked 1e-6 as a small number, but it might not be small enough for your example -- in that case, try 1e-20 or whatever. But "if(FL==0.0)" is much more specific. Just like alarm bells should ring if you ever type "1/3", you should ask yourself whether a tiny value is just as bad as "(FL==0.0)". Maybe, in the circumstances, you should also ask whether infinity or NaN (not a number) are also possibilities. |
c_udmi, source, udf |
Writing a new variable as output | kuria | OpenFOAM Running, Solving & CFD | 7 | May 12, 2021 14:01 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 01:17 |
equationReader in combination with variable expansion | philippose | OpenFOAM Bugs | 5 | January 23, 2012 14:58 |
Transient post-processing, Time averaged pressure work | Turbomachine | CFX | 1 | January 3, 2011 18:01 |
variable viscosity -NOT! | George Bergantz | Main CFD Forum | 15 | September 19, 2000 15:28 |
