Segmentation fault error in User defined memory UDF
Old   September 12, 2018, 05:09
Default Segmentation fault error in User defined memory UDF
up
abhi12019 is on a distinguished road
I want to initialize four variables to fluent memory, but during initialization getting segmentation fault. Below is my UDF:
#include "udf.h"
#define Latent_Heat 397500
DEFINE_INIT(initialize,d)
{ cell_t c;
Thread *t;
d = Get_Domain(2); //domain ID is 2
thread_loop_c(t,d) /* Loop over all cell threads in domain */
begin_c_loop(c,t) /* Loop over all cells in a cell thread*/
C_UDMI(c,t,0) = Latent_Heat;
C_UDMI(c,t,1) = Latent_Heat;
C_UDMI(c,t,2) = 1.0;
C_UDMI(c,t,3) = 1.0;
C_UDMI(c,t,4) = 1.0; /* Liquid region */
end_c_loop(c,t)
Thanks
abhi12019 is offline   Reply With Quote
Old   September 13, 2018, 00:16
blackmask will become famous soon enough
You should check the pointer before deference it.
#include "udf.h"
    cell_t c;
    Thread *t;
        if (FLUID_THREAD_P(t) && NNULLP(THREAD_STORAGE(t, SV_UDM_I)))
            end_c_loop(c,t);
However, generally people do not use
DEFINIE_INIT
in the way as you do.
blackmask is offline   Reply With Quote
Old   September 13, 2018, 02:58
up
Thank you for your response, the macros is define in the UDF manual as the way I defined(Ref. UDF Manual November 2013, ANSYS Release 15, P-26).
I want to save the previous time step values for liquid fraction as C_UDMI, so that I can access those values during the calculation. As you said the way I defined is not the way defined, so What are the other options to define DEFINE_INIT?
Old   September 13, 2018, 04:17
For your purpose
DEFINE_EXECUTE_AT_END
is more appropriate.
segmentation fault, solidification/melting, udf, udmi
Received a fatal signal (Segmentation fault) with UDF lisa_china Fluent UDF and Scheme Programming 2 June 30, 2017 04:07
Fluent UDF Wall Shear Stress Segmentation Fault a1ananth Fluent UDF and Scheme Programming 3 February 24, 2015 04:23
user defined memory (UDMs) Musa FLUENT 1 October 16, 2012 22:12
User Defined Memory sreekargomatam Fluent UDF and Scheme Programming 7 May 19, 2012 05:56
use of user defined functions (UDF) Vedavyasa M FLUENT 0 June 27, 2007 07:21
