Pressure Outlet UDF
Old   August 30, 2018, 04:38
Default Pressure Outlet UDF
Madrid
miguwhynot is on a distinguished road
Hi, I'm trying to set up and atmospheric air flow over a sphere, so I have a velocity inlet with the desired velocity and a pressure outlet with the UDF for pressure.
#include "udf.h"
DEFINE_PROFILE(pressure_inlet, thread, position)
face_t f;
real t = CURRENT_TIME;
real v = 4;
real t1 = 11000/v;
real t2 = 20000/v;
real t3 = 32000/v;
begin_f_loop(f, thread)
if (t <= t1)
F_PROFILE(f, thread, position) = 101325.0*pow(((288.15-0.0065*v*t)/288.15),5.25577);
else if (t <= t2)
F_PROFILE(f, thread, position) = 22605*pow(2.718281828,(11000-v*t)/6340);
else if (t <= t3) {
F_PROFILE(f, thread, position) = 2447*pow((141.89+0.003*v*t)/216.65,-11.388);
else {
// Capture t values outside the allowed range:
// print a message to the console and stop.
Message("%d: Error: t=%e not allowed.\n",myid,t);
return;
end_f_loop(f,thread)
As you can see the UDF basically simulates the ascendent move of the sphere at "v" velocity.
I'm having trouble making the problem work with no physic model turn on, just conitnuity (getting reverse flow at outlet). Can you spot my mistake over here?
Also I'm not completly sure what to set in Operating Condition pressure (I think the value should be zero since my UDF gives the total pressure value). Thanks everyone in Advance.
miguwhynot is offline   Reply With Quote
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 02:37
UDF for pressure outlet backflow total temperature MrDaimon FLUENT 13 June 23, 2017 01:45
Question Concerning Pressure Value (Pressure outlet) and Reference Pressure (Physics) andy_flow STAR-CCM+ 1 July 9, 2013 09:44
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 18:19
