Cavitation UDF -- VOF of phase 2 is 0
Old   August 27, 2018, 01:13
Default Cavitation UDF -- VOF of phase 2 is 0
seinfeld2 is on a distinguished road
I'm trying to hook the Schnerr-Sauer cavitation model via UDF but I'm having an issue. The model requires multiplying by the volume fraction of the second phase but if my entire domain is water, the vol fraction of water vapor is always 0 so the mass transfer never starts. Does anyone know how to solve this issue?
seinfeld2 is offline   Reply With Quote
Old   October 18, 2018, 07:01
cfdxyz is on a distinguished road
I have the same problem. The source term in the default Sauer cavitation model could work even when I set entire domain as pure water. I have no idea how the source term works. However, the Sauer cavitation model written in udf could work when I set a very small value of vapor volume fraction in the initial condition.
In addition, there is a difference that can not be neglected between the default Sauer cavitation and Sauer cavitation model written in udf in pressure distribution.
cfdxyz is offline   Reply With Quote
Is there a VOF (CST) foam code for phase change into the air media? Asghari_M OpenFOAM Programming & Development 4 February 17, 2021 11:41
UDF for modifying density of mixture phase during the calculating process sola86 Fluent UDF and Scheme Programming 2 May 28, 2019 10:24
UDF for energy source in VOF model Harnoor Fluent UDF and Scheme Programming 3 August 1, 2018 20:34
UDF Parse Error - Initializing VOF for Multiphase Simulation denbjornen Fluent UDF and Scheme Programming 0 April 25, 2018 03:07
UDF of "anisotropic phase function" in radiation modeling whiz Fluent UDF and Scheme Programming 0 September 1, 2009 04:26
